Grinding wheel sale *LINK*
Robert Henderson
>Hartville Tool is having a sale on the Norton 3X Grinding wheels
1. Are these wheels good for HSS turning tools?
2. Would I want I-Grade or K-Grade
3. Which two grits would be best for use with HSS turning tools?
4. Are these superior to the white Norton wheels that Lee Valley sells?
5. Is this really a good price?
Link to grinding wheel sale
Re: Grinding wheel sale *LINK*
>Robert,
Doug Thompson told me (at least this is what I have in my notes!) that he uses the Norton K, 46 grit wheel to shape the Thompson tools. He gets them from Hartville. 46 may be better for shaping but a little coarse for final sharpening.
Greg Haugen
>Robert, IMHO, here are my answers to your questions.
They are one of the best wheels for HSS tools.
For our Purposes the "k" grade is best. "I" is a little soft and grooves very easily resulting in more dressing and less wheel life. It will work but you'll dress it alot more than the "k" shortening it's life.
This is a personal preference. IF you go by "K" you'd have a 46 and 80. The roughing wheel really doesn't matter, you just want "coarse". As far as sharpening, many turners use the 80 grit to sharpen-it's a common choice. Some turners like a 60 grit wheel to sharpen while some like a 100 to 120 grit.
Yes, IMHO. Their makeup is partially ceramic, not just AO. Ceramic is a very cool grinding media, it cuts fast and clean. Ceramic is becoming a new and common substance in woodworking and turning. 3M's ceramic sanding discs I think are the best discs, definately the longest lasting, on the market.
Yes. I've never seen the wheels under $40.
Hope this helps,
Greg Haugen
Doug Thompson near Cleveland
>Robert,
To touch up an edge try the 80 grit K grade, the 46 grit is made for shaping. These wheels don't grove and last a long time... matter of fact I'm still on the orginal 80 grit wheel used for the finish grind on spindle gouges. Well over a thousand tools hit this wheel and it's just under 7 inches. Now the 46 grit to shape the tools are abused so they don't make it past a couple hundred.
To save a wheel I found Bill Grumbine has a single point diamond dresser that trues the wheel and removes very little grit. I don't know anymore about the dresser but it's the one I like to use.
>Hi Doug,
Me thinks it is the Oneway dresser.
Jorge
>>...Me thinks it is the Oneway dresser.
From Bill's web site:
This wheel dresser, manufactured by Sierra Mold in Carson City NV, is designed to index itself off a support table used with many grinders. One side is used for the popular Oneway Wolverine and other larger tables, and the other side is used for smaller tables. The wide range available with the threaded post allows this tool to be used with virtually any grinder and table combination on the market today.
I'm not familiar with the Oneway dressing jig. (I was about to buy the one that Bill carries.) I found a picture of the Oneway on the Rockler web site and compared it to the picture on the Sierra Mold web site and they don't look the same - the Oneway looks like it swings from a low pivot while the Sierra appears to slide along a rest.
Sierra Mold Dresser *LINK*
Dave Smith, Longview, WA
>I have the Sierra Mold Dresser and I believe it is better than the Tormek dresser. I use it on my Tormek and my slow speed grinder. It can be used on virtually any grinder.
Dave Smith
Made shaving today, I must be dreaming in Longview, WA.
Sierra Mold Dresser
That's the one...
>I own the Oneway and find it's hard to use while Bill's locates off the tool rest which is straight forward and easy to use. While we are talking wheel dressers I have found once the wheel is true make a small adjustment and go across the wheel ONE time to get the finish I want... more than one time gives a finish that doesn't cut as well.
Hand held dressers work but I've been known to dig in once in a while and better yet put my own bounce in the wheel. LoL
