Re: Lathe motors -
Curly Smith
>The short answer is "yes". The long answer is "it's complicated".
As Jesper said, the 1200 RPM motor is more expensive and more massive than the 1800 RPM motor as these links illustrate:
Baldor 1800 RPM
Baldor 1200 RPM
The 1800 RPM motor is $327 and weighs 46 lbs while the 1200 RPM motor costs $510 and weighs 74 lbs. There are certainly applications where the more expensive motor is the best choice but a lathe may, or may not, be that case.
The lathes that deliver insufficient torque at low speeds are likely equipped with a "variable torque" VFD (or what used to be called "constant HP" VFD) when they probably should have used a "constant torque" VFD.
In general, a "variable torque" VFD has a speed ratio of 5:1, meaning that an 1800 RPM motor can be slowed to 360 RPM (a 1200 RPM to 240 RPM) and a "constant torque" VFD has a speed ratio of 2:1 so an 1800 RPM motor can be slowed to 900 RPM (a 1200 RPM to 600 RPM). The limiting factor in both is heat generation in the motor.
So, you should get the performance that you want with an 1800 RPM motor, a "constant torque" VFD, and, as others have mentioned, step pulleys to give the desired lathe speeds.
FYI - it's best to buy the motor and VFD from the same place unless you're certain that both will work (a) together and (b) in your specific application.
