>What is the best way to mount a large diameter piece? I have a future platter that is 28" dia. and 3" thick, mostly dry about 65lbs. I have a PM 3520 with the drop down bed extension. I was going to do my initial shaping with the piece mounted to a faceplate. My challange will be when I flip it to turn the interior, will a glue block hold? a chuck?
I think you are on the right track by using a faceplate to begin, using lots of screws. Keep in mind that when the shaping is done and it is time to reverse it, most of the weight will be gone. At that point a large glue block might work, but personally I'm more comfortable with the holding power of a chuck.
Ric
But then again, I'm not young enough to know everything.
>I talked to Lissi Oland a few weeks ago about this. She had a just-finished 33" maple bowl on her big lathe.
She always fastens the face plate to the work with Gorilla glue and screws. The page on her web site about the largest piece mentions: "Large 9" facepalte, 8 2.5" lag bolts, will give it a bead of Gorilla Glue" She mentioned not to overdo the glue or when it expands it can overflow the center hole in the faceplate. http://www.olandcraft.com/Big_pieces/Biggest_piece.html
She said this always holds. Note that the lathe speed is very slow.
The other lathe in her shop had a fairly thin piece of uneven burl which would be unbalanced when turned. It was mounted with Gorilla Glue only - no screws. This is not much different from gluing on a waste block.
BTW, I have a friend who has turned many fairly large bowls by holding the blank to the facelate with good quality double-sided tape. He applies one layer of tape to the face plate, one to the work, and burnishes the tape before removing the backing so it will adhere well. This holds large unbalanced pieces so well it is hard to remove them. Woodcraft sells good tape.
If you give Lissi a call I'm positive she will gladly provide advice based on years of experience with many large pieces.
>Once you've removed most of the imbalance and shapped the back, A large chuck should hold fine. Be sure to use it in expansion mode in a recess rather than a spiggot. Much stronger grip that way.
>...expansion mode in a recess is not as secure as compression gripping a tenon. For a large platter there will probably be less chance of splitting out a recess with a wide enough edge, but any wobble in the process will dismount a piece more surely that a compression mount.
>I am one who prefers a chuck in expansion mode. On a piece this size, I would probably use a face plate on the front as the throat on my drill press isn't that deep. The biggest I have is 6 inch, and if the tailstock is used, it will hold fine as long as you don't try to turn at 1,000 rpm and have a catch. If you have a bigger face plate, use it. I would use my big jaws which are 5 inch diameter in a dove tailed recess about 1/8 inch deep, for reversing and turning out the inside. How secure your hold is depends on how big your recess or tenon is, and how close the fit is. For 5 inch jaws, you want a 5 1/16 recess, and a 5 1/4 diameter spigot. The closer the fit is, the more metal you have on the wood. The more metal on the wood, the better, think 2 inch jaws on a 4 inch tenon, or into a 4 inch recess, almost no metal on the wood. Both recess and tenon hold well when properly done. I think dove tailed jaws will hold better than straight jaws, or if you are using a tenon, then the serrated jaws. On a bowl this size, 5 inches is kind of minimal, but I don't know if any one makes bigger jaws or not. Again, having the tailstock on will add holding power, but I don't know if that is possible on your outboard turning set up or not. Again, don't turn at your highest speeds. Actually, you will probably have more trouble with chatter/vibration of the wood with that size diameter, so you will have to turn the inside down in stages, and won't be able to go back to the top for one final pass from the rim to the center. I don't think you can make a steady rest that size and mount it on your lathe.
1. Mount and turn with face plate (turn as much of the platter to finish thickness and sanding as you can)
2. Mount on foot side spigot (to the tenon you left for that purpose when mounted on the faceplate) finish turning the hollow of the platter leaving a small tenon (1/8" to 1/4" high)
3. Mount on the small tenon to finish the foot
4. Use a belt sander to flatten the inside of the platter removing the small tenon.
