How short should I make the bed of my lathe?
wilbur
>Thanks to Jim's post in the WC classifieds, I'm the happy owner of a Conover lathe. For those of you who aren't familiar with this lathe, it has a wooden bed. This particular lathe is made of microlaminated plywood built up to make a pair of beams 10 feet long, effectively giving this lathe a capacity of 7 feet between centers.
I got it home, and found that I have a slight issue. The lathe is too long for my shop. Of course, this is a good problem to have, and honestly, I suspected that I would have to do this, but it looks like I'll have to shorten the bed, which is easy, of course, since it's made of wood.
So my question is, coming from someone whose longest spindle piece so far has been a tool handle, how much capacity should I reserve for myself? I've got a few notions kicking around:
1. 42", because that's what most 16" swing lathes (Jet, Oneway) seem to have as their between centers capacity.
2. 54", because that seems to be the longest capacity between centers for any lathe being made today without the use of bed extensions. (Robust Sweet 16 and Vicmarc VL 300 long bed, in case you were wondering.)
3. Shorten it just enough to put it in the spot that I have for it, which would give me about 5 feet between centers.
4. Keep the bed as is, and rearrange all the other stuff in my shop to make it fit.
I'm leaning towards option 3, but one thing I don't have a good handle on is if the capacity over 40" is going to be wasted. Looking at the things around my house, it seems that most of the turned spindles, like table legs, stair railings, etc., are at most about 3 feet long. Over that length, the only thing I can think of that would require turning would be the corners of a four-poster bed, which jumps straight to 6+ feet. In other words, I'm not sure how often I would need to turn something between 3 feet and 6 feet long, in which case I might as well chop the bed down to give me 42" between centers. If I made the lathe that short, I could make use of the extra space that it gives me.
Of course, what's going to happen is that 10 minutes after I cut down the bed of this lathe, my wife is going to want a four-poster bed, even though she's on record as highly disliking that style of bed.
Re: How short should I make the bed of my lathe?
Wally Dickerman in Arizona
>Wilbur, many long turnings such as bed posts are turned in 2 pieces using a tenon to join them.
If you use option 3 you can always shorten the bed again if you want to.
Wally
>My preferences - I turn legs - chair, table, etc. and bedposts. The longest leg that I've turned was ~36". That's pretty much the maximum I can turn. I'd like to be able to turn about 10" longer.
If I was turning architectural stuff, I'd want to turn over 4' sections between centers (probably 54").
My $0.02.
Richard Allen
Richard Allen
>Imagine turning a large bowl with your longest bowl gouge. See where you elbow swings. You want to be sure the tip on the live center is not in the way.
For me that works out to about 41" between centers. Add a few inches for safety and you will be able to leave the tailstock on your lathe when you don't have hunks of wood between centers.
You also need room to mount and dismount "stuff" from the lathe bed (like the tailstock, captive hollowing rig, steady rest...).
Bill Grumbine - Kutztown PA
>Wilbur, I'd make it as long as I could. Like Wally says, you can always make it shorter. Besides, all that extra bed length is a great place to store stuff!
Bill
Steven Antonucci
Lengthen your shop
steve antonucci
>Once you cut it down, you can't put it back.
I'd opt for moving other stuff to accomodate the length. Maybe knock a few feet off of a jointer or something ;-)
Steve
E.T.
>If you decide you have to shorten the bed, go with No. 3. If you ever need a longer bed, it does not take much time to make a long set of beds.
I made two sets of beds for my own Conover, a short one and a longer one. In hind-sight, I should have made the short one shorter and the long one longer.
ET
>Wilber,
I found that 42" is a few inches too short for making a "regulation" size shovel handle so I had to make one a little short on my Jet 1642. I haven't measured the rake and hoe handles.
bill Crommett
>Wilbur:: Cut the bed to a length you feel would give you room for what you suspect is the longest spindle you intend to make. Then if in the future you need to make a one-off of something longer you can always bolt the tailstock to the wall and go from there. That is what i did with my Shopsmith when I made a laminated railing five feet long for my daughters boat. If you need a longer lathe when you build your new shop, Glue-lams are not that expensive nor are they hard to come by.
Brian Hahn in SW Wisconsin
>I had three different beds for my Conover. I started with a bed that gave me 48" between centers and a very short bed so I could use it as a bowl lathe (no tail stock). The bowl lathe bed had about 16" beyond the head stock and was dropped 2" to give me a 20" capacity. I eventually made a third bed that gave me 18" between centers.
I rarely used the long bed - tool handles are about the only thing I used it for (I like long handles). The intermediate bed was plenty long for everything else that needed to be between centers. Most of the time I had the bowl lathe bed on. (I don't like standing in the throw zone when I'm turning bowls.)
long as possible
Jake D (SoMN)
>I used to own a conover (and really miss it) I would make the bed as long as possible. since the tailstock clamps from the bottom you lose some travel when sliding it to the right because it hits on the legs. When turning bowls I was constantly hitting the tailstock so I would have to lift it off the lathe so it was more comfortable to work. If the lathe was a little longer I could have slid it far enough out of the way.
Good luck and enjoy your new toy...you will not be disapointed...
Jake
Thanks
wilbur
>Thanks for the input, everyone! I'm going to shorten the lathe just enough to put it into the spot that I have for it. I spent a good chunk of last night trying to figure out how to keep the lathe its current length, but every floor plan I came up that was good for the lathe would have made everything else in my shop worse. I think I'll still have 4-1/2 to 5 feet between centers after shortening the bed.
wilbur
>Thanks, Wally -- didn't think of that.
Storage
wilbur
>I do need all the storage that I can get, since I don't have that traditional piece of storage equipment -- a table saw. :@)
