drilling boxes & vessels
Carol - now back in Dubuque, IA
>Any thoughts about the type bill for drilling out boxes or vessels to speed up excavation?
I've seen Forstner bits used, but they get really hot [gotta kill the sharpness]. Rockler has one that has plenty of room for waste to get out but they want $35 for the 2+ inch model. Yikes!
Anybody try a big spade bit, like the one with the spur tips? Gotta be less expensive for a 2-1/8" or 2=1/4" [bigger than the chuck].
Re: drilling boxes & vessels
Ron McKinley
>You can excavate a box much quicker with a heavy duty scraper than you can with a Forstner bit. If you use a Forstner bit you still have to use a flat nose scraper to get rid of the hole that the point leaves.....Ron
Ken Tampa an NC
>I use an auger bit and some times a spade bit.You said the bit got HOT right,well the same thing happened to me untill my brain woke up and I turned the lathe down to the slowest speed,then I put the bit in the tail stock and slowly run it in the piece,taking it out about every 1/2" or so to let the chips out,If I am doing real dry wood,I will even sray WD40 on the bit once It starts getting deep in the wood.Take your time and don't force the bit.Since I started that I havn't had any problems and am still using the same bit.
>Carol,
Two things:
First, I usually use a set of carbide tipped forstner bits that don't seem to get as hot as my "normal" forstners. They may not leave as perfect a surface as the expensive bits, but that doesn't matter when drilling for turning. (I've used them mostly to bore out pepper mills - the carbide bits work well even with very hard woods.)
Second, when drilling, I stick a small diameter nozzle on a compressed air line into the hole behind the drill and blast it with continuous air flow while drilling. This keeps the bit MUCH cooler and more important, it keeps the chips clear. I suspect keeping the chips clear reduces friction which helps with the cooling as much as the airflow. I don't necessarily use a real high pressure/volume, but that wouldn't hurt anything except your ears.
Wally Dickerman in Arizona
>Carol, as you may recall, I use a hand held 3/8 in. drill. I use it as a depth gauge and to make the hollowing easier. By the time you get through using a forstner or spade bit, I'll have most of the hollowing done, using a gouge or a scraper. With practice, you'll do the same.
Wally
>I agree with Wally. I tried the big drill thing and just didn't like it. I went back to the 3/8 to use a a depth gauge and then hollow with a bowl gouge.
Ditto
Carole Valentine
>IMHO, drilling is for depth only. Waste of time to try and clear a lot of wood with a drill. That's what your turning tools are for.
To each his own *LINK*
Ron in Drums PA
>I use a forstner bit
In the video I'm using a 1-7/8" bit and I'm drilling into some pretty hard bubinga.
Vid
>I did remember, Wally. Using it as a depth gauge slipped my mind though. Not to mention not having the spur points to deal with.
I saw a demonstrator at the club meeting last week use a bit to drill out a bird house, so I was wondering...
And at Indy Fest, Al used a bit to start a vessel. Different strokes, as they say.
I HAVE 3/8" bits, even 18" long ones. Don't need to buy something else. LOL!
How I love the brain trust here!
Re: To each his own question
GalenV
>Ron
Do you remember what rpm you were drilling your 1 7/8" hole?
I've used a 5/8" but never anything that big on the lathe.
My lathe lowest speed is 500 RPM.
Seems like feed rate would need to be slow or you would need a tight grip on the piece, as it is taking a big bite!
Your bit is probably in better shape than mine!
Thanks
Galen
Brad Vietje
Brad Vietje
>Hi Carol,
Honestly, I can't think of anything quicker and/or easier than a standard high-speed twist bit -- say 3/8" or so -- and a spindle gouge on it's side, followed up with a scraper. This does not require exotic or difficult cuts like "back-hollowing", just flute to the left, and a pivot cut to the side.
For those with a wider range of tools available, a hook tool, or a ring tool like a Termite works real well, too. I have a 12" long 3/8 bit that I hold in vice grips, and a shorter one mounted in a wooden handle for all these sorts of drilling jobs.
The times I DO use a Forsner bit or similar, is in making pepper mills or things where a more precise cylinder is needed for the parts to fit correctly -- but that's not so often for me.
Safe spinning,
Brad Vietje
Newbury, VT
Ron in Drums PA
>I normally drill around 600 RPMs
I'm not Ron, but...
>Here are several references: "http://images.meredith.com/wood/images/pdf/speedchart.pdf" and "http://www.qtm.net/bcwg/Documents/drillspeed.pdf" as well as "http://www.rockler.com/product.cfm?page=10675".
For Forstner bits of any size, I don't like taking them above 250 rpm. For the smaller ones, I rarely go over 500.
but...
Ron in Drums PA
>The forstner bit isn't spinning
And on the shaft it reads that it is rated for 620RPMs
Carole Valentine
>Right, sometimes they do come in handy, like when you are making tea lights, clocks, etc. I don't make them much anymore so I tend to forget about them. The other thing I use a Fostner for is to drill a flat hole through the bark of what's going to be a natural edge piece so I can set my spur drive in solid wood.
Michael Stafford
>I don't use a drill. I use my spindle gouge to rough out the wood and finish the interior with a scraper or a Hunter tool.
I can rough out the inside of a simple box in less than a minute without any starting hole.
>Carol, fit a round knob or a pistol grip handle to one of those long bits....easier to use.
Wally
Re: Ron and JL - Thanks!
GalenV
>Thanks Ron for your input and JL link to speed charts.
Yah, at cutting surface the speed is relative regardless of what is turning, bit or wood.
Reason I ask is from another experience:
When I first starting to turn pens I purchased Fisch Vortex-D brad point drill bits, as this is what the Woodsmith Store had in metric.
The package for 7, 8 and 10 mm listed a recommended speed of 2000 to 3000 rpm. This was a Lot higher than brad point bits I have used in the past, so I ran slower. In hard woods and plastic the old slower speed charts did not work! Talked to the factory and with their center shape you needed to turn the bit as fast as they recommend and use a pretty fast feed rate to get a clean hole and not burn the material.
Later I was told by a lot of pen turners they just use twist drill bits and run slower than most charts and they work just fine.
Guess you never know till you learn by experience what works for you.
Thanks again,
Galen
>Thanks for the reminder. I remember that now. I'll put it on my to-do list.
I would avoid Spade Bits....
Jennifer@Indy.USA
>The thin shaft of the spade bit is just asking for trouble in my opinion. A 1/2" bit should take care of any entry hole you need to create. Then get you a good hollowing tool like the Hunter, or a ring tool or make a hook tool. There's nothing sweeter than watching the curls come off any of those tools. Forstner bits take all the fun out of it!
Sorry I missed you at Indy Fest Carol :(
Jen
