Forstner bit upgrade???
Rich Pearson in Mill Creek, WA
>It's time for me to get a better set of Forstner bits.
What do you use?
What brand/source would you recommend for the crispest, cleanest cut?
I am willing to spend a few bucks to get excellent results!
Thanks
Re: Forstner bit upgrade???
Greg Haugen
>The best, fastest cutting-cleanest cut, bits that I've found are also the most expensive I've found. They're not bad if you're looking for a few common sizes, just don't look at the "full set" price.
Bormax Forstner Bits
http://www.woodcraft.com/family.aspx?familyid=1917
Greg H.
>Tough choice. I have a larger set of Rockler bits that I've used for years. My sister gave me a set of the Lee Valley smaller ones for Xmas one year - they are very nice - better than the Rockler.
Those are the only sets that I've personal experience with. I do have a single Freud bit and it is very good.
My $0.02.
Re: Convalco *LINK*
Russ Fairfield
>Connecticut Valley Manufacturing Co. The best there is, and they are available from Morris Tool. They are definitely not cheap.
Morris Wood Tool
Richard Allen
Richard Allen
>Just like most tools sharp is the key.
High carbon steel are the cheapest and easiest to sharpen but they can be overheated in use and lose the ability to hold an edge. Depending on how often drill holes this could be your best choice.
High Speed Steel bits are much more expensive but the stay sharp longer. They are more difficult to sharpen but it is nearly impossible to heat HSS enough to lose the ability to hold an edge.
Carbide bits stay sharp for a very long time and can not over heat in use. They are usually sharpened with diamonds. They are also the most expensive.
Mike Nelson
>Not sure what you are using them for but I bought a box of eight Porter Cable bits (less than fifty dollars) and have used the 1 3/8 on over a hundred cabinet doors and still going. Also use the largest one for quick start on deep vases.
Re: Convalco, I second that!
>True, they cost more but give years and years of service.
They are the original Forstner bit manufacturer, proudly made in the U.S.A. by fine american craftsmen.
Jorge
Thank you! I've
>ordered my Freud Carbide Tipped Forstner bits.
As always, your input is greatly appreciated.
