Passmore Elm?
Passmore Elm?
Passmore Elm?
Steven Kubien
>The remanents of Ike came through southern Ontario on Sunday night/Monday morning. Around me, numerous trees were downed. I approached one home owner and asked if he could identify the logs he had cut up at the curb. He said it was from a passmore elm. I have googled and gone through my (very limited) texts and can find nothing about passmore elm.
It's pretty pale in colour. The leaflets show 5 symetrical, narrow, toothed leaves (two up either side of the twig and one at the end). ANy ideas of what else this may be called? I picked up a couple of pieces which will make nice 8-9" bowls and another crotch piece (probably a vase or HF).
Thanks for your help.
Steve Kubien
P.S. picked up some manitoba maple as well. Very bland colour but will bleach nicely.
Re: Passmore Elm?
Re: Passmore Elm?
>Is it a compound leaf with five leaflets with pairs on the "twig" directly opposite each other? Elms don't grow that way but there are several hickory trees that usually have 5, sometimes 7 leaflets with symmetrically opposed pairs - shagbark, pignut, and scrub. Hickory leaves are narrow, pointed. Elm leaves are wider and "rounder", more sharply toothed on the edges. See any seeds or fruit? Is the bark distinctive?
One of the best ways to identify the wood is to shave a small section of the end grain with a razor blade and look at the pores and rings. Elm is ring porous and has a distinctive wavy small pore latewood pattern. The picture below is one I took by holding a small digital camera up to the eyepiece of a low power microscope. You don't need more than a 10x lens to see the wood.
Re: Passmore Elm?
Re: Passmore Elm?
Steven Kubien
>Hey John,
I think you may be correct about it being a hickory. My trek through the text's keys led me that way.
If you/we are correct, how soon do I need to rough this stuff before it cracks all to h*ll? The only hickory I have ever used was bone-dry 2x material for an axe handle.
Thanks,
Steve Kubien
Re: Passmore Elm?
Re: Passmore Elm?
>The hickory I've cut on my sawmill has all been boards and blanks for handles and such, up to 4" in diameter. I didn't see any significant cracking. (The white sapwood is much tougher than the darker and figured heartwood.) But for a big chunk I would certainly anchorseal the ends, keep it in the shade and as wet as possible until ready to use, and like other green wood, rough it out as soon as possible.
I do have a pecan log section (nearly the same as hickory) that's about a year old and is holding together nicely. One of my books says of shagbark hickory: "no other commercial wood has the combination of strength, toughness, and elasticity."
