Thanks John Lucas!
Thanks John Lucas!
Thanks John Lucas!
Michael Stafford
>I came home for lunch and found a package in the mailbox from John Lucas. I opened it and to my surprise there was a wonderful hand made depth gauge from John, the one where he uses carbon rods as the measuring stick.
What a wonderfully useful gift. Maybe I won't turn through the bottom of as many boxes now.
John, I appreciate that you took the time to make, package and send this wonderful useful tool to me. It is an act of generosity I will not forget.
Thank you very much!
Re: Thanks John Lucas!
your welcome Mike. Pass it forward
Picture, Mike!
Carole Valentine
Ditto!!
greg_haugen
I'll work on a picture.
Michael Stafford
here you go
>This is a slightly larger version of the one I made Mike. They are easy to make. I bandsaw a cut in from the side. Then drill a hole every so slightly larger than the rod through the bandsaw slit. I put a small clamp on the piece to keep the wood from flexing while I drill the hole. Then I use a carriage bolt with a wing nut to lock the rod in place. If you don't go to the trouble of routing the edge and use a straight piece of wood you could build one of these in 5 minutes.
I hate when I do that. :)
>By the way Mike. This is 100 year old Chestnut.
Thank you John, I was wondering...
Michael Stafford
>what kind of wood it was. My first thought was some kind of oak but antique chestnut makes it better.
Thanks again.
