turned boxes
turned boxes
turned boxes
bq in vt
>A turned box question: can you turn a box with the grain running perpendicular to the axis of rotation(faceplate work) or do they have to be turned with the grain running parallel to the axis like a spindle? I have watched Richard Raffan's video and all of his were with the grain running parallel to the axis. Thoughts? Opinions? As always, thanks for your time.
Re: turned boxes
Re: turned boxes
>I have done a fair number of boxes with side grain vs end grain. In smaller size they work pretty well but your lid will fit differently at different times of the year. Usually it's bad just a little snug at times. some end grain woods will do that also but not as bad.
On larger boxes which I call lidded vessels you do get quite a bit of movement with some species so I make the lids a lot looser on these.
Re: turned boxes
Re: turned boxes
Michael Stafford
>I agree with everything John said. I might add that on face grain turned boxes I make no attempt to have a "fitted lid". The lid just sits inside the open in the body or overfits a body flange but is fitted so that it is an easy lift off.
Re: turned boxes
Dick Hines
Re: turned boxes
Dick Hines
>I am not an expert. All the boxs I turn that are not burl wood are turned end grain. The burl ones you just have to go to it and hope you don't get much movement.
Re: turned boxes
Re: turned boxes
>It may just be the burl that I turn but I find burl wood to be the most stable.
Re: turned boxes
Re: turned boxes
keith zimmerman, Normal IL
>I agree with Mike and John about turning face grain boxes. I always fit mine with loose fit lids. Most often the lid will overlap the rim of the bottom.
keithz
