Expanding chuck
Expanding chuck
Expanding chuck
pat28
>Hello fellow turners! I have a stupid question, but I'd rather ask than have a large chunk of wood fly into my face... I bought myself a General International 4-jaw chuck for a midi lathe. I really appreciate the versatility and reliability of it, but I was wondering whether this type of chuck is also intended to be used as an expansion chuck. If it is the case, do I need to remove its four jaws and flip them over? Thanks very much for your help!
Pat
Re: Expanding chuck
Re: Expanding chuck
>I'm not familiar with the General International chuck. If it is a wood holding chuck with circular jaws then you don't have to reverse the jaws. If it is a metal holding chuck with narrow stair step looking jaws you would have to reverse it however I would not use it to turn wood. It won't hold the wood properly and you will launch the piece.
Re: Expanding chuck
Re: Expanding chuck
Dick Coers
>Another concern about expanding chucks is the loading on the wood is completely different. If you get too thin of a rim and turn too agressively, the rim can split off on the short grain. Most of the wood chucks have a thin ring in the jaw that will deform the wood and get a grip in the wood.
Re: Expanding chuck
Re: Expanding chuck
robo hippy
>If the jaws are slightly dove tailed (about 7 degrees I think) then it will work fine for expanding into a recess for holding bowls to turn. A straight jaw can work as well, but needs a deeper recess for a good grip. The recess you cut should match the jaws of the chuck as closly as possible, in angle and diameter. I have used a recess to turn and core bowls up to 18 inch diameter. The recess is about 3/16 deep for the bigger bowls, and 1/8 inch deep for the smaller bowls. You also need to leave a fairly broad foot for the jaws to expand into. On a 14 inch bowl, I leave the bottom about 6 inches wide, and my recess is 2 5/8 inches wide. If there isn't enough shoulder to expand into, it can break under the pressure of turning and tightening. When tightening, you need it snug, but don't get it as tight as you possibly can. If you over tighten, you can actually break the foot, or it can be under so much pressure that if you have a catch, it will fail as well. Do experiment to find out what works best for you.
robo hippy
