Getting Started - Chair Legs & Spindles
Paul Leuba - Hunt Valley, MD
>I have built a couple Windsor chairs recently from kits where the legs and spindles are already turned. I would like to "graduate" to a full function capabilty where I turn the legs, stretchers and spindles myself for future chairs.
However, I've never used a lath. I plan to enroll in a turning class at the local Woodcraft store, and then begin shopping for a lath.
Can the forum members advise me on the characteristics I should look for in a lath to do this work? And, is there a particular lath that is suited specifically for this work? The legs and spindles are all under 24" in length. Maple for the legs and stretchers, and red oak for the spindles.
Any advice you offer would be greatly appreciated.
Paul in Hunt Valley, MD
Re: Getting Started - Chair Legs & Spindles
>Paul,
I suspect some chair makers (like JL) will give their advice, but many lathes will do what you need. I've had a couple.
My list of important features for this type of spindle turning includes variable speed (very useful but not absolutely important), long enough bed (almost any mid/full sized lathe), at least 1 HP motor, and as heavy and sturdy as possible although a heavy lathe is more important for turning large bowls and things which may have far more imbalance than a chair leg. You can tell a bit by the size of the threaded spindle on the headstock - 1-1/4"x8 is a standard size on a number of healthy lathes. I would not want one less than 1".
I've had a Jet 1642 variable speed lathe for years now and I like it very much. The bed is long enough to turn almost everything, except I had to knock a few inches off a "standard" shovel handle! It's also a very capable lathe for bowls, boxes, and other things. (Know that turning wood is highly addictive and you may soon want to make other things.) There are many other lathes that will also work - everyone has their favorite and most people seem to be happy with what they chose, perhaps a testament to the general quality and utility of the lathes on the market.
One big consideration is your budget. $2000 will get you far more lathe than $1000. The worst thing you can do is buy the cheapest lathe you can find, although used lathes of excellent quality are sometimes to be found.
Another thing to remember is more is needed than the lathe. Some other things for turning spindles (bowl turning has a longer list):
- good tools - roughing gouge, skew, spindle gouges, parting tool
- a way to sharpen
- calipers and measuring instruments
- sanding and finishing supplies
A turning class is an excellent way to start. There are also many good books that will explain the how and why. A couple of my favorites for learning basic turning are "Turning Wood" by Richard Raffan and "Fundamentals of Woodturning" by Mike Darlow. There are DVDs and videos as well but I find the books have more detailed information and are better for understanding the "why".
You may also find a woodturning club and other turners in your area. A turning club is wonderful since you can watch demos, ask questions face to face, and learn from experienced turners.
>I've made several chairs but only two true windsor designs. I have however turned a lot of spindles, for myself and as replacements for other chairs. A lot of lathes will work for what you want to do. A good quality mini lathe such as the Jet mini with a bed extension will work. It's a little underpowered but for nothing but spindles it will work fine.
many many chair parts have been turned on lathes with 12" swing and 3/4 horse motors. I would recommend the new Jet 12/20 with a bed extension. If you want more mass and more motor look at the Jet 14". If you have more money look at the Nova 16/24 with bed extension. All of these will do the job you want to do.
I learned to turn windsor legs on a spring pole lathe. We carved most of the leg on the shaving horse and then turned the tenons on the spring pole lathe. That was how Curtiss Buchannan had us do it. I love it. I could never use the skew before that. The spring pole lathe moves slow enough that you can actually learn the skew.
Taking classes will not only let you experiment with other lathes but will increase your learning curve dramatically.
>Lathes - you really need about 30-36" of bed capacity - how you get there is your business. A mini with a bed extension certain works as does a bigger lathe. I prefer at least 3/4 hp, preferably more for turning spindles. A variable speed lathe is definitely a plus, though not totally necessary. You don't really need a lot of distance between the ways and the center of the spindle - 12" will definitely work.
I like my Jet 1642 EVS. I've turned on the Nova DVR and it is also good. I've turned on Jet Minis with bed extensions and they work fine. Other lathes are the new Delta Midi with bed extension and the General Maxi Lathe with a bed extension.
As far as your spindles - I would use straight grained white oak as opposed to red oak. Red oak has a coarser, wilder grain and is not as strong. I usually rive my spindle wood and then use a drawknife and spokeshaves to get them round. I've turned spindles before. As you get down to 3/8", they get a bit whippy and the pressure of your lathe tool against the work piece really gives you a lot of deflection. If you want plans for a shaving mule or shaving horse, let me know - I can point you to some designs that I've used. If you want one built, I could do that too. The picture below shows a piece with a lot of spindles :).
My $0.02.
>John:
You hit all my points of interest. Thanks much for the thoughtful feedback
Paul
>John:
That's very helpful information on the lath size/power. I hoping to not make a large investment in the lath starting out because, at this point anyway, my real interest is in chair making and not so much in a larger turning endeavor.
Regarding useing a shave horse to carve the Windsor legs, was the style a staigtforward oval shape, or did you actually carve a more intricate design?
Thanks
Paul
>Thanks, JL, for that feedback.
The lath information on capacity/HP is very helpful. I will check out the several models you mentioned. It appears that Jet is a very popular brand for laths of this size because several other responders to my post mentioned Jet.
I will take your advice on white oak for the spindles, as well as using a shave horse to make them round. One of the last things I did before taking the Windsor chair class at Woodcraft was to purchse the shave horse plans from Lee Valley/Veritas and build it. I used 2" white oak, and it is really sturdy.
Thanks again!
Paul
>Thanks to everyone who responded to my request for advice on using a lath for turning chair legs and stretchers.
As I progress with my lath training course, equipment purchase and early efforts to use it, I will almost certainly need to get further advice on the forum. It's great to know that there are skilled craftsmen, such as yourselves, willing to take the time to share their knowledge and experiences with others.
Thanks for all the advice.
Paul
>Paul they were sort of the bamboo design but each of us added our own shape. After that I made one with double tapered legs. Since I'm a turner all of my latest legs have been in the turned windsor style.
>Thanks, John! I have not considered the shave horse as a possible source of Windsor leg development. I am going to follow through on my lath training efforts and will keep the shave horse in mind as a fall back if my lath skills don't develop as I hope.
Regards,
Paul
