end grain
DaveG
>I would like to make a cutting tool for end-grain turning. Are there any links which describe how to do this? I have seen two write ups on hook tools but did not know if that is the best way to go or not.
end grain
DaveG
Hook tools work great in end grain
steve antonucci
>Depending on the size you need (box size or large bowl?), you can hammer out a hook in about 15 minutes if you have a MAPP torch.
The Hunter tools also works pretty well (I've seen it used, but not with my own hands...) I doubt you could make one though unless you had access to a machine shop.
Steve
Re: end grain
Greg Haugen
>Hook Tools are one option. Easy to make and very versatile. Once you get the hang of them, they're great. The biggest mistake people make is not having them at an angle, if the cutting edge is presented at a horizontally to the wood, no angle, you get the mother of catches. When they're shearing, at an angle, they're great. What are you making?? That would be helpful to know, there are other things that could be used depending on what you're turning. I recently spent some time with Alan Lacer at his shop. We made hook tools and practiced with them. We also did alot of work with scrapers, shear scraping and using a burnisher to raise different sizes of burrs for the application we were working on. "light" burrs for final shearing and heavy burrs for roughing. It was great. My favorite two scraper for that is a 3/8 square beading/parting tool ground to a round nose scraper-very versatile tool and thick for it's size since it's square. As well as a 1/2" wide scraper that's 3/8" thick. Hamlet makes it. Alan sells it and so does "Traditional Woodworker". Identical grind just a bit more heft to get deeper or to remove more material in roughing. I've also used the Ray Key spindle gouges, which he uses for hollowing end grain boxes. They remove material quite well and with the bevel is rubbing it's a nice finish cut as well. It works almost like a hook tool, a hook tool is basically a mini gouge at a 90 degree angle. I've never used it but Soren Berger's tool is suppose to be good as well. The action of Soren's tool and the Key gouges are very close to hook tools. All of these tools are used from the center out in traditional turning. I recently made an end grain Walnut Vessel, deep bowl. I hollowed it with bowl gouges cutting from the outside in and had the best finish of any tool I was using. With the right grind, it's glass smooth and no tear out. Which is more of the Stuart Batty technique. There's less vibration because the force on the wood is back toward the center of the rotation. Going from center out, the tradtional way-which is the correct way for the hook tool or scraper, applies a force away from the rotation, which in a heavy cut will cause vibration.
If you're talking more about "hollow vessel" turning tools, the Ellsworth style is the easiest to make, straight or bent.
Hope this helps,
Greg Haugen
Re: end grain *LINK*
Don Orr
>Darrell at www.aroundthewoods.com has a tutorial on his site about making hook tools. Look around the site under making tools. I think Alan Lacer does too. As Steve said they work well on end grain.
Making a hook tool
Hook tools inside end grain hollowforms
steve antonucci
>I have been playing around with it, and I actually got it to work. They cut much easier and cleaner than the Ellsworth tools do, The problem is extracting the cut material from that little tiny hole.
This form is 13" deep, and the hole is roughly 1". I used the hook to remove most of the interior after drilling the depth hole, and it was only my first, very crude hook...
Steve
>I've made hook tools and ring tools. I also own a Termite ring tool. I'll take my Hunter tools anyday over these. The hook tools and rings tools aren't that hard to sharpen but you do have to attend to that frequently. If you let them get dull then they are a pain to sharpen.
The Hunter tool on the other hand never needs sharpening and won't clog up the way the ring tools do. You can't make the tip, it's polished carbide and you need the correct screw with a tapered shank to hold the tip onto the metal bar. If your handy with a file and very small drill and tap you can make a holder for the Hunter tips.
http://www.hunterwoodturningtool.com/
Re: Hook tools inside end grain hollowforms
Greg Haugen
>Absolutely they'll work. That's how the whole Moulthrop family does their vessels is with the Moulthrop Hook Tools. I think Craft Supplies specially makes them for them. I talked to Rex about them a while ago and they make "batches" throughout the year when Matt or Philip order some more. The tools are pretty large compared to the usually hooks.
Greg.
Hunter tools
>I have a variety of the Hunter tools on both end and side grain, inside and out, and just started using a couple new ones with bent shafts for closed forms. They work very well on end grain and inside the pieces I've done so far - easier for me to "feel" the ridges and get a consistent wall thickness. I think they cut better and cleaner than the hook tool, Termite, and various scrapers and hollowers I have and have used. I do use a sorby teardrop scraper for final surfacing of what can be seen or felt.
Re: Hunter tools
Allen Neighbors
>You and John L are right, John. I also recommend the Hunter tools. I can't even count the number of lidded boxes I've made with the first one I bought at SWAT. I stopped counting at 22 or so, and I've made at least double that amount. All with the #1 tool.
His service ranks up there with Oneway's, too. I broke one tool cutter when trying to get it loose to turn it; He replaced it. You can't beat Mike's cutters for end grain boxes.
