THE WOODRAT IS BACK!
Eucalyptus
Eucalyptus
Eucalyptus
Ken Oakley-Sunny St. Cloud, Fla
>I have an opportunity to get a fairly large amount of Eucalyptus from a large tree that is going to be cut down. Need comments on qualities as a turning wood. Good, Bad, or Ugly.
Re: Eucalyptus
Re: Eucalyptus OT
Michael Stafford
>I don't know a thing about eucalyptus but it did remind me of a joke I heard.
911 Operator- 911, what is the nature of your emergency?
Caller- My wife fell off the balcony and is severely injured.
911 Operator- What is your address sir?
Caller- 234 Eucalyptus Street
911 Operator- How do you spell eucalyptus?
Caller- silence
911 Operator- Sir, are you still there?
Caller- Look, I am going to drag her over to Oak Street and y'all can pick her up there....
Re: Eucalyptus
Great wood!
Ron McKinley
>Eucalyptus is a great turning wood. Sometimes it has beautiful grain like curly maple or a tiger-stripe. I've only turned it dry so don't know about turning it wet. ....Ron
Re: Eucalyptus
Re: Eucalyptus
Tommy Holmes
>I have been able to get one "silver dollar" eucalyptus tree about 9" in diameter and it really warps and cracks. It has a nice pinky orange color. I turned one bowl from it and left it plenty thick. I then soaked it in DNA for several days and when drying it warped so badly I couldn't turn it round again. It also got several large cracks in it, maybe 3/8" wide. I have cut some squares from it (without pith) and coated them with Anchor Seal and they have split although not as wide of splits as the bowl. I have left the logs, coated, to see if anything is left from them after the crack. Some of the have 3/4" and 1" wide cracks on the interior. They have not split to the exterior yet.
Pretty wood but I don't know that I would spend a lot of time and effort to get more than a little of it.
Just my experience.
Re: Eucalyptus
Re: Eucalyptus
>I will probably cut most of it into pen blanks to sell on Ebay so cracking is not a real problem. I just cut around them
Re: Eucalyptus
Re: Eucalyptus
>If it's anything like Lyptus (a eucalyptus hybrid), I think it's a great wood to turn. The photo below is a bowl I did a few years ago (oil finish).
The wood is pretty hard when dry - a guy gave me this blank after cursing at it a bit then giving up on it. He said it was like turning concrete but I thought it was fine. I ribbed him a bit and told him he just needed to learn how to sharpen a gouge!
Re: Eucalyptus
Re: Eucalyptus
Tommy Holmes
>The eucalyptus I have is about the color of your bowl.
I got hold of a piece of lyptus when I first started turning bowls and I agree with your friend.....like concrete. And yes, and that point I was struggling with sharpening. I've still got some left and thought that I would try it again some day. I may pull it out and give it a try. Pretty bowl, by the way.
Re: Eucalyptus
Re: Eucalyptus
Chip in Plano
>Lyptus is great stuff for turning (and flatwork). I like the varied hues and ribbons.
Isn't all turning better with sharp tools? If I'm having a bad experience, I stop and sharpen. The calming zen of sharpening and the sharp tool always make returning to the lathe better...even when it's quilted maple.
Re: Eucalyptus
Re: Eucalyptus
michael serpa
>There are so many different kinds of eucalyptus that it is impossible to generalize. Try some and see what you get.
Re: Eucalyptus
Re: Eucalyptus
Jason Clark - Arizona Woodturners Association
>Most of the turners in the Phoenix Metro area tend to avoid Eucalyptus, particularly when it's to be turned green. As a general rule it cracks and warps more than anything else that's available locally. It also tends to be as hard as concrete when turned dry.
Jason
Re: Eucalyptus
Re: Eucalyptus
Jim Shewan
>I think the types of eucalytus number into the hundreds but by all means give it a try. Some have amazing colours and but the types I have tried shift a lot if not well seasoned although this can be used to advantage. Some logs left untouched for years have large fissures and cracks in them and yet the sound wood still retains enough strength to hold it all together which can make for some interesting pieces.
Re: Eucalyptus
Re: Eucalyptus #2
Jim Shewan
>This was turned from a stump in the ground for many years. The ground had prevented the wood from drying out so there was a huge amount of warpage almost imediately after turning.
Re: Eucalyptus
Re: Eucalyptus
Chris Krohn
>I am a fairly new turner and got some eucalyptus at a firewood dealer that I turned fairly wet to the final thickness. It warped to a pretty cool shape and did not crack. It also gets crud stuck on your tools and lathe so clean the gouges afterwards.
