Holding work in a chuck
bob henry
>In a case where you have to hold a piece in a chuck and you can't have jaw marks, how do you do this? Thanks for any help.
Bob
bob henry
Bob
Re: Holding work in a chuck
Greg Haugen
>What are you trying to hold onto? A bowl? A box? something else?
Greg
Richard Allen
>Vacuum chuck
Button jaws (Vicmarc has terrific "buttons")
Use dovetail jaws and make a like sized dovetail on your bowl (or whatever) The closer your dovetail is to the size of the chuck jaws when close the less the workpiece will be marked.
Jam chucking
Brian Simmons, Heflin, AL
>Bowls and platters can be held by means of a vacuum chuck, cole jaws, double sided tape, hot glue, waste block, and jam chuck.
Smaller items can be held in a collet, jam chuck, or between friction disc and live center.
If you are having a problem or need to know how to hold something in particular please be more specific.
bob henry
>I trying to hold a spindle that has already been turned and can't get jaw marks on it.
Bob
Dennis Yoder
>If the spindle is round where you are trying to hold it you can make a collar out of another piece of wood. Turn the collar round with a center hole a little smaller than the piece you want to hold. Cut the collar in two and place around the spindle. Insert into the chuck and tighten. Make it as long as possible for more grip. It is possible to hold a spindle quite nicely. Learned this trick from Ed Moore at JCCFS two weeks ago. Dennis Y
>>...make a collar out of another piece of wood.
I did this just tonight. I was making a lid out of eastern red cedar (very, very soft) and I had only about 1/8" tenon to grab to finish the top. No way I could grab it with a chuck without destroying it. I turned a ring with the ID a slip fit over the tenon and the OD to fit a chuck. Removed a small wedge with a saw.
Thanks to Ed Moore for showing us this technique.
If you turn a small lip on the ring it can register against the front of the chuck jaws to simplify alignment.
I turned this ring from the same cedar instead of a harder wood. It gripped very tightly and did not leave a mark. If the ID was too sloppy and the ring had to be compressed significantly, I might round off the sharp corners on the inside of the notch.
Attached is a quick rendering of the idea, from the chuck side. (It's quicker for me to make a 3D model than take a photo!)
Ronald Nelson
>I keep a wide selection of sanding drum sleeves ( the kind for sanding on a drill press) on hand for doing that. The cardboard like material is thick enough to keep the chuck jaws from marking up the finished piece.
Ron Nelson
>There will be a tip by Mark StLeger in the next issue of American woodturner on this exact technique. I did the photos for the tip and used this method to turn a handled sugar scoop.
I turned the insert out of a limb section.
bill Crommett
>I recently made a lid out of eastern red cedar, and to finish the top I wrapped several layers of paper tape around the flange to protect the flange from jaw marks.
