Re: Placement of sand in lathe stand
Keith Newton, LR, Arkansas------WebKitFormBoundary
>You may find that there would be some improvement higher up, but there will still likely be some or a lot of movement if something is bad out of balance, if the stand is too limber to allow flexing where the lathe is bolted to it.
If I wanted to turn one of these little open legged stands into the ultimate stand, I would use the legs as the outer corners of a solid poured concrete base.
All you would need to do, is form up to the outside of the legs, work in some re-bar, and pour it full of ready-mix concrete, then wait for it to cure.
When I built my big lathe, I started with a massive casting of a headstock, then welded up what I thought would be plenty strong, out of 1/2" and 1 1/2" thick steel, but it could still wiggle a little, as surely as a bell rings. I then took it back apart and poured concrete into the cavity, while throwing in big iron cast plugs to add more weight.
The concrete cube did the trick. After I was done, it dawned on me that I could have just formed up and poured a little pyramid cube with a flat top and bolts sticking up where the lathe sits much easier than what I constructed.
