Scheppack Tiger 2000 Grinder
elliott
>Does any one have any feedback on this wet grinder. Amazon has this for $100.00 I do have the Wolverine jig
Re: Scheppack Tiger 2000 Grinder
>Elliot I bought one for $100. First let me say I've been through all the wet grinders except the Tormek. I'm also really good with a dry grinder. I got a good deal on a bunch of carving tools and really wanted a way to speed up sharpening these things. Here's my thoughts on this machine.
It isn't a Tormek. There are some quality issues but then it didn't cost $600 either. The motor doesn't apply enough pressure against the drive wheel so it slips. I got around that using a .79 cent spring I got from the hardware. Bend the ends 90 degrees and attach it to the motor and the housing and you can't stop the wheel. That's the #1 complaint that Tormek uses to downplay this tool. Problem solved.
I'm kind of a perfectionist and not although it does seem to sharpen the tools quite sharp I still feel there should be a grade of grit between the fine and the buffing wheel. I think tools should be sharpened to about 1500 grit before buffing and this only goes from 250 to 1000 using the grading wheel. That's another problem. If you want to sharpen one tool that is need reconditioning you have to grade the wheel down to 250, grind, regrade the wheel to 1000 and grind. This eats up your wheel. Not much of course but each time you do it lessens the life. The wheel is smaller than the tormek and possibly the Jet and Grizzly. I've seen the Jet and but not used one. It looks like a better built tool and the wheel may be larger. It appears the accessories will fit but I haven't purchased any yet. I've been building the accessories I need but it's certainly simpler to just purchase them.
I don't use it for turning tools. I simply don't feel they need that sharp an edge. I've tried it, they do get sharper but I'm not convinced it cuts any longer before I have to sharpen and I have to deal with the mess of bringing water into the shop and emptying it. I do use the final honing wheel on the skew when I think about it but mostly I still use my diamond hones on that.
One reason I don't use it for turning tools is my shop is dry. So I have to the house to get some water and start the wheel up and let it soak. I could have sharpened them on the grinder 5 times in that amount of time. It changes the shape of the wheel if your not careful and then you have to true it up to sharpen plane irons and such. Consequently I leave it for flat woodworking.
I think a belt sander beats this machine for sharpening carving tools, at least the way I like to sharpen. I can quickly change to any belt grit I need for rough grinding or I can step through the grits in even small steps if I want. I don't have one right now, I used a friends but it's on my list. The Lee Vally 1" strip sander is perfect but you have to supply your own motor.
At $100 I think it is definitely worth it. I use it sharpen most of my flat woodworking tools although I still touch up the plane irons with the Scary sharp sandpaper on glass system. I think it gives a better edge. When I get the belt sander it will be interesting to see which system I stay with. I will obviously have to build more accessories to sharpen the various tools.
I think the Jet and Grizzly might be better machines but they do cost more. However you are also sure that the accessories will fit.
I have looked at the new Sorby belt sander sharpening system. It's really sweet looking but just about as expensive as the Tormek and that's not in my budget. A 20" disc sander and Horizontal Bandsaw are in that price range and I need those more.
Re: Question John- I haven't played ......
Jamie Donaldson
>...with the Sorby belt sander, but have tried the Grizzley on my bowl gouges, and wonder in which direction does the Sorby belt approach the tool edge? I found that a belt that cuts into the edge rather than away from that edge rounds over the bevel slightly, rather than the preferred concave or hollow ground shape from a wheel. I have had a Makita wet grinder for many years for flat work tools, and wouldn't consider a belt grinder unless the direction of the rotation could be reversed or runs upward or away from the edge to be sharpened?
>Jamie I'm not sure about the Sorby but the carvers belt sander all run in reverse, that is they travel uphill from bevel to the edge. That keeps you from rounding the bevel and of course prevents kickback as well.
Allen Neighbors
>Jamie, I switched the motor around on an old Sears 6x48 sander, which makes the belt run the other direction. It works like a champ. You're right, direction of travel makes the difference. No bevelled cutting edge to worry about. I like a flat bevel on my skews, so this is what I sharpen them on. I also sharpen all my spindle gouges, and a myriad of other tools using this belt sander with a 125 grit belt.
Re: Sorby Pro-Edge
Ron McKinley
>The Sorby Pro-Edge runs from top to bottom approaching the tool from the tip.......Ron
