Sit down lathe stand
Jeff L
>I can't stand up to work so had to come up with a stand I could sit at. I found one on one of the forums and somewhat copied it. I tiped the lathe a little which also helps. So far it has worked great for me.
Re: Sit down lathe stand
Don Orr
>Glad to hear it is working for you. Looks like a very nice setup. Seems awfully clean though. ;-))
>Jeff That's very similar to the stand I built for a man in a wheel chair who wanted to turn. We also found that tilting the lathe made it easier for him to work. I lost track of him after he moved so I don't know if he's still turning or not.
Like the stand. Have you considered making the..
>tilt adjustable?
I don't know how easy it would be or whether or not it would be to your advantage.
Re: Like the stand. Have you considered making the
Jeff L
>The tilt can be adjusted. The front bolts can be drilled at different locations to raise or lower the front. Could do the same with the back two bolts. I just drilled them with the amount of tilt I thought would work with the thought that I could cange it if needed. So far it has worked out just right.
