reversing super nova chuck
peter kolb
>Hi, how do I run a super nova chuck in reverse with out the chuck unwinding from the spindle? Thanks for your help Peter in south central nj
peter kolb
Re: reversing super nova chuck
>Peter It depends on what you are doing in reverse. If your turning medium to big bowls you would need a set screw of some sort to hold it on the spindle but you also need a spindle with a non threaded area to accept this. A good catch can make the spindle come unscrewed really fast. If your confident in your turning skills you can get away with it.
I only sand or turn some small things in reverse so a good tightening of the chuck is all that's been necessary.
>Teknatool makes a special insert with a set screw for this. I ordered a few through Woodcraft to fit the Jet 1642 and Powermatic (1.25x8 thread?).
Carole Valentine
>Peter, your insert should have a threaded hole for a set screw and your lathe should have a flat where the set screw contacts the spindle. Many places were selling the chuck inserts for the SN2 without the threaded hole for the set screw. If yours is one of these, I don't recommend turning in reverse with it. Get an insert that you can lock onto your spindle. Another thing...don't forget to remove the set screw when you try to remove the chuck...you can damage your spindle threads! You can get a set screw with a brass tip on it. Since the brass is softer than your spindle it's less likely to harm your spindle should you forget and try to crank the chuck off with the screw still in place.
Jerry McCaffrey
>There ate two set screws you need to worry about. Technatool chucks (G3, Titan, and Supernova) use a threaded adapter to the diameter and pitch of your lathe spindle. There is a set screw on that adapter, at least if you have the genuine Technatool one. Then there is a set screw on the body of the chuck, locking it to the adapter. Not fastening either will allow the chuck to spin off the spindle or the adapter when reversing.
Re: reversing super nova chuck *LINK*
Gordon Seto
>Get the Insert L
Insert/Adaptor Listing for Nova chucks
Don Evans
>Over 50 years ago, some lathes were using brass wafers under set screws where the set screw would touch threads.
If you drill and tap your own insert, just find a solid piece of brass rod that fits into the hole, cut a 1/8" thick piece off the end of the rod and drop it into the hole, then insert the set screw.
You can also purchase set screws with plastic tips but I prefer the brass method.
Don
peter kolb
>Thank you all for your help Peter in south central nj
Allen Neighbors
>Well, I finally got my computer repaired.
I bought one of those little Nova Compac chucks from our friend in GA, to mount on my Little Vic. I then configured the Vic's motor to reverse. When I turned it on, the chuck promptly spun off. So I remounted the chuck, tight, and drilled and tapped a hole in one of the Hex flats, and put a 1/4x20tpi set screw in it. When I drilled the hole, I went through, and into the threads so the grub screw sets in the indent. I've had it off a couple of times, and the threads aren't buggered, but just have a little indention.
Never a problem since.
