Pendants
Pendants
Pendants
>I blew up a hollow cherry vessel yesterday so I decided to quit and go on to something else. I got these scraps of wood from a friend who just got back from Finland so I made some pendants for necklaces. The top right one will be a pendant with a clasp glued to the back. That one isn't done yet, I still need to clean up some glue and sand a little more.
These were turned by gluing them to a rectangular piece of scrap. Then I removed 2 jaws from my chuck and mounted the wood with the top pulled away from the chuck bottom about 1/4". Then for the second turning I move the wood up about 3/8" and pushed it in slightly.
Re: Pendants
Re: Pendants
Don wilcut
>These are great John
Don
Re: Pendants
Steven Antonucci
Are the all turned?
steve antonucci
>I always struggle with trying to figure out if they were entirely turned and how it was done. I can see that a cuple of them appear to be multi-axial, but I can't picture the setup?
Thanks in advance.
Steven
Re: Pendants
Re: Pendants
RonZ
>Great job John, I'm just trying to figure out how you did it. Some how I can't picture it. Maybe it can be an article you can write for somewhere.
Re: Pendants
Re: Pendants
bill Crommett
>John : I hope you will amplify your directions, too. These are beautiful as well as novel.
Re: Pendants
Re: Are the all turned?
>Steve They are all turned except the bottom right natural wood one. I decided to use the scroll saw and dremel to make one and see what the difference is. The others are all multi axis pieces. Well 2 axis. The wood was wedge shaped. I glued it to a rectangle block. Then remove 2 jaws from my chuck so I could turn it on multiple centers. Since the wood was wedge shaped I also tilted my waste block out at the top about 1/4" so I was cutting reasonable flat on one face.
The face one broke out at the top. The wood was too crumbly. This is like Colorply but much much softer. That is the reason I glued the ebony to the back and added eyes. It turned into a fun piece.
Re: Pendants
Re: Pendants
>I'll try to put something together. Read my response to Steve for some ideas. I got the idea from Woodturning magazine and then expanded on it using a chuck instead of screw centers which gave me the ability to tilt the waste block as well as slide it up and down.
Remove 2 jaws from your chuck and put a rectangular waste block in there. Glue a chunk of wood to it and just play. You can draw on it with a pencil with the lathe off to see what will happen. It's harder to see what happens when you tilt the block. There are so many possibilities. I'd love to own an Escoulen chuck so I could really play with multi axis but I have to pay my car insurance first and that won't leave much left over for toys.
Re: Pendants
Re: Pendants
Don at Central Illinois
>Toys! Just what is more important. You need to get your priorities straight! heh, heh. You never cease to amaze me. I don't even have those thoughts, let alone the time to experiment. These are great.
