200+ woodworking book reviews
Rikon Lathe
Rikon Lathe
Rikon Lathe
Sam Scalzo
>Has anyone purchased a Rikon Lathe? What is your take on it ?
Do they make a varabl3 speed? Thanks for any info. Sam
Re: Rikon Lathe
Which one?
>I've turned on the small one and I believe that it is comparable to a Jet mini. It doesn't come in variable speed though.
I've seen the larger one (20 x 36 Woodfast lathe) at the IWF show. It seems to be a reasonably well made solid lathe. It is a variable speed (with 4-5 power ranges). But for a little more ($200-300) you can get a Powermatic.
Re: Rikon Lathe
Re: Rikon Lathe
>I just spent a long day at the IWF looking at mini lathes with a friend. We decided the Rikon was the best buy, dollars vs what you get. We both liked the new Delta VS a lot but it was twice the money. The Jet 12/20vs is a good lathe but again it was higher priced. My friend decided to order one of the Rikon's.
I've turned on most of the mini's out there. Most have minor differences and all turn about the same. The Jet and the Rikon have the best reputations for not falling apart. The Rikon has the best belt changing system. In fact it's belt is so easy to change I would stick with the single speed motor. You get more power. VS is really nice depending on what you turn. The type of thing I turn on a mini doesn't need VS.
Re: Rikon Lathe
Steven Antonucci
I have a Rikon Bandsaw
steve antonucci
>I can tell you that I've had an 18" Rikon Bandsaw for about 3 years, and the quality is very good. I could have spent a lot more money on a better saw, but it was hard to justify 2x the cost.
I haven't regretted the purchase.
Steve
Re: Rikon Lathe
Re: I have a Rikon Bandsaw
Ken
>I have the Ricon mini,it was my 1st lathe an I still have it,although I have since upgraded to the Nove 1624 before I killed the mini.but I turned pieces up to 11" and even used the McNaughton coring tool on it.So much for the power question.It takes me about 10 sec. to change the speeds.Also there service dept is great to work with.Thumbs up on my part.
Re: Rikon Lathe
I have the Rikon Lathe...
Carol in Illinois
>and I'm really happy with it. It's very stable and runs very smoothly and powerfully. It's very accurate, no wobble... takes any add-on I throw at it... Changing the belts, even for a newbie like me, is a cinch. I'd choose it again, in the same size range.
Re: Rikon Lathe
Keith Tompkins
Re: Rikon Lathe
keith tompkins
>HI Sam, I have a 12" mini-midi as well. I use it for demos and as a student lathe. Good power, and has a chip deflector over the motor...a buildup of shavings is probably what causes most Jet mini's motors to overheat and go up in smoke. No problems so far!
Re: Rikon Lathe
Re: Rikon Lathe
Sam Scalzo
>Thanks to all on the info on the Rikon Lathe.
Sam
