Have a question? Ask Woody!
Nova 3000 Lathe
Nova 3000 Lathe
Nova 3000 Lathe
Jim Canning
>I have a Nova 3000 lathe with the Leeson Speedmaster motor control,it was given to me last year and I had never turned it on. Then we moved 1400 miles and after the move I plugged it in and turned it on. The motor starts right away but it runs as if someone was turning it on and off. I was wondering if someone else has had the same problem, I checked the fuses to see if they were loose and they are not. I can't tell if they are blown, they look as if they are white ceramic.
What should I do?
Jim
Re: Nova 3000 Lathe
Re: Nova 3000 Lathe
robert davis
>leeson controls need adjustment. you need manual to tell you how to adjust...torque ans i comp controls.i have a 3000 ..needed adjusting when i got it six years ago. been ok since
Re: Nova 3000 Lathe
Re: Nova 3000 Lathe
Ed Heuslein
>Jim, your IR Comp control needs adjusting. I wouldn't touch the torque 'till you have the IR Comp adjusted first. I like to put on something a little heavy - about 5 pounds and balanced. Turn the lathe on and adjust the IR Compt 'till it starts running smoothly. It may have to be touched up again with heavier loads later. Torque shouldn't need adjusting unless it's been adjusted before. If so, check the manual and do the suggested default setting. That usually does it. Have fun, and enjoy the lathe. Ed
Re: Nova 3000 Lathe
Re: Nova 3000 Lathe
Don Evans
>Jim:
The motor and controller that you have was added to the Nova by www.Woodcraft.com . If you contact there customer service they should be able to provide a manual for the adjustments.
There are several potentiometers along the edge of the circuit board that have to be adjusted in a specific order or it will not work correctly.
You can purchase a new circuit card if your's is in trouble from
www.surpluscenter.com for $70.00. Just do a search for minarik.
You want the one that handles 90 and 180 volts output. If you have the Leeson 1 hp you set a jumper or switch in the controller for 90 volts if you have the 1 1/2 HP motor you set it for 180 volts.
There is also a jumper or switch for the voltage input 115 or 230 volts.
Don
Re: Nova 3000 Lathe
Re: Nova 3000 Lathe
Darryl
>The speed adjusting knob on the Leeson controller needs to be at more than 50% or you will get surging of speed.
Re: Nova 3000 Lathe
should not surge at any speed if set properly
robert davis
Re: Nova 3000 Lathe
Re: Nova 3000 Lathe
Toney Robertson
>Ed,
What is the "IR Comp control" and where is it? My 3000 does surge at times. It is usually goes away when I either get it up to 50%+ or change to a lower speed range with the belt.
Thanks,
Toney
Re: Nova 3000 Lathe
Re: Nova 3000 Lathe
Jim Canning
>Yes it was the IR Comp control , Thank you your info saved me lots of $$$$$$. It works great!!!
Jim
Re: Nova 3000 Lathe
Re: Nova 3000 Lathe
Jim Canning
>It is in the Leeson Speedmaster motor control box. Take the cover off (unplug it first)and you will see 6-7 little round dials, mine was the last one one the right, they are marked. I turned it to the right and that did not help so I turned it all the way to the left and that did the trick.
Jim
