most oaks are difficult to dry...
GaryG in MD
>Doug,
Most oaks have a very high warp ratio. See
http://web.hypersurf.com/~charlie2/Turning/WoodShrinkage/ShrinkageT_R_TR_ratio.html White oak is in the middle, but the red/black oaks are at the bad end of the scale. That makes it likely that your blanks will crack as they dry, and it also means that if you turn round roughouts, they will become quite oval and no longer flat.
See http://books.google.com/books?id=hW13qhOFa7gC&pg=RA1-PA306&lpg=RA1-PA306&dq=wood+shrinkage+ratio&source=web&ots=OESI1nym5N&sig=0sym8JCwDcFrkVnsx-y-eGSDp-c&hl=en&sa=X&oi=book_result&resnum=4&ct=result
for specific comments on oak.
Other turners here may differ, but I think your best bet is to turn them round, or nearly so, keeping the maximum possible diameter, and to something like twice your desired final thickness. Immediately recoat them completely with a sealer. Keep them in a place like a wine cellar -- cool, dark, high humidity -- for at least a year.
Alternately, if you have the capability, you might consider boiling them right now. You can look up the procedure here and elsewhere. Many people find this to be quite helpful. See, for example, the experience of Jim King, for whom boiling is SOP. That may go a long way to reducing the probability of cracking, and it will shorten the drying time considerably.
When they're dry and you re-turn them to round, you can expect to lose around an inch of diameter. They will probably move again too, so if you want them really flat, leave them a little thick because you may have to re-turn them a second time after a day or two.
You will also find that turning dry oak isn't much different from turning stone. Expect a lot of dust even with a sharp gouge.
Good luck, and let us know how it turns out. ...Gary
