3M Airstream Question
Steve in NC
>I am pretty careful with safety. I wear a faceshield most of the time, run the DC while sanding and where a dust mask often. However, I have not turned in 8 weeks due to knee surgery and in that time I have found I am breathing better and my seasonal alergies have not been as bad. My conclusion... In spite of my efforts, I am still exposed to too much dust.
After reading the posts here at WC, I have decided to take the plunge and buy a 3M Airstream. My only concern is with the durability of the face shield. I routinely replace my regular face shield when it gets to the point where I cannot see (due to finishes and/or sap...). How do you folks deal with this issue with the Airsteam. I know that the Trend has covers that you can replace. I do not see the same option on the Airstream.
You comments appreciated.
Steve
Re: 3M Airstream Question
Darryl
>Steve before you take the plunge I suggest you look carefully at the new Trend Pro. It is a very competitive unit to the Airstream. As for your question you might try the page protectors for loose leaf notebooks or go to a place where they sell dirt bikes. the face protectors for the bike helmets might just work.
Terry Quiram, Roanoke Illinois
>Steve
3M sells removable face shield covers for that unit. The covers have sticky stip along both edges. I have used an AirMate for close to 15 years and haven't scratched the face shield because I use the removeable covers.
bowlman
>I have used the 3M Airsdtream since it was called a Racal Airstream ... nearly 30 years. The best way to maintain the face shield, or any face shield for that matter, is to clean it daily with a product called Novus. Comes in 3 grades or steps. Step 1 is for removal of light dirt/or dust. Start with step 2 for medium scratches and gunk removal, then finish off with step 1. Start with step 3, then 2, then 1 for really major stuff. But like I said, if you clean it on a regular basis and don't let the stuff get caked on, step 1 is really all you need. See eBay for sources.
Also, there is a company called AirAmerica (I think that's it) that sells everything you need for a 3M, including the stick on replaceable films.
Airware America
Greg_Haugen
>Your source for all safety equipment. Not associated with them in any way.
Greg H.
Re: Airware America  *LINK*
Greg_Haugen
Airware America
Fog Tanner
>I use the Airstream anytime I go to the lathe. I use the protective "tearoffs" (as they are called on racing helmets) and my visor is still like new. I buy them by the 10 pack from Airware America, which is also where I got my Airstream. If you buy your Airstream from them you can also pick up their starter or combo kit that contains a filter and extra protective covers and save a few bucks.
My only regret is not getting the Airstream a lot earlier, it would have saved me a lot of lost time work due to sinus and allergy issues. They were always good for three days of down time, during which time I couldn't work due to the headaches. With the Airstream they went away, and that includes turning Aromatic cedar to which I am allergic (along with Oak and Elm).
Re: 3M Airstream Thanks
Steve in NC
>Thanks for the advice everyone. I found the shields and I am going to try the cleaning methods on my regular face shields.
In response to the suggestion of the Trend Pro, I tried it and did not like the way it felt on my head. I am also concerned about its filtering effectiveness. I spend a good part of my day preaching safety and trhe use of proper personal protective equipment to my field crews. From what I have read, This is a one time purchase so I think I will go with the Airstream. (although I still cannot figure out why is costs so much.)
Thanks again for all your input.
Steve
