TURNING GREEN 1ST TIME
CARL BARTON
>I recently obtianed some Bradford Pear logs approx 9in in Diamiter and I cut these down to about 5in in lenght each. I have a 14in bandsaw so this size makes it easier for me to cut. I now have 17 chunks of wood approx 9in DIA x 5in long. I coating all these sections with sealer to slow down/stop any cracks.
Never haing turned green before I got myself a book on turning green wood and I am now reading it. I just wanted to find out from others when one turns green can I turn one of the above size chunks of wood without first cutting it down the center (down the pith) or must the pith be taken out before turning? In another woods, do I need to cut the above mentioned chunks of wood down the center to create two halfs?
Carl
Still learning, but having loads of fun.
Re: TURNING GREEN 1ST TIME
Don at Central Illinois
>It really depends on the end use. Are you going for a vase, long and narrow? Or are you wanting bowls? For bowls, you should probabaly get rid of the pith and actually rough turn the bowls to about 1/2" thick. Then coat with an end grain sealer and/or wrap in newpaper, tape shut and make sure you put the date on it. They should be ready in about 6 months for final turning. As for the vases, they shold be not only end sealed, but put into a grocery bag, to slow down the drying. As with all fruit trees, they are really prone to checking and cracking. Good luck and I'm sure some more experience turners will add to this.
Dick Coers
>All fruit woods will crack very easily, even with the end grain sealed. I'm surprised that after a couple of days your blanks aren't already cracking. I would put them in paper grocery bags or wrap with newspaper to slow the drying even more. It's my experience that in pieces that diameter, that you should stay at least an 3/4" away from the pith. So you will end up with a 1 1/2" "board" that has the pith in it. If you get much closer to the pith than that, it will really distort in the bowl or vessel. You can use the sides of the board for pen blanks, Christmas ornaments, or bottle stoppers. You should probably do some reading or research on drying the rough turnings with alcohol for even better luck. Bradford pear turns like a dream, but can be a little boring if there are no character marks or color.
CARL BARTON
>Thanks Don,
I am thinking about doing bowls for now. I did not even think about a vase. I have put sealer on everything right now because I can not get to all of them to cut up further today. The wife and I are going to head out to Gettysburg for the long weekend. As always thank you for the advice.
Carl
CARL BARTON
>Dick,
Thank you for the advice. You are correct, it turns like a dream. I turned a few small bowls about six months ago when I received the logs. They are a bit bland as you said, but it was free wood and since I am only starting out I get I get lots of practice from the free stuff. The couple of bowls I did do did crack within a day. I ave learned a few tricks since then. I turned two more small bowls three days ago and put them in a bag with some of the shavings. Still no cracks yet. :) There were some cracks on the ends of the logs I had but they did not go very far into the logs when I cut them today, but I did seal everything to today to make sure there were no more cracks.
The logs I had were each about six foot long and I could not cut them down to size until I found a chain saw, which was today. I did not want to buy a chain saw since they scare me a bit, but we are moving to Wisconsin in a few years to 40 arces with lots of hard wood on the property. SO I am thinking I might need to start learn how to use a chain saw and turning more green stuff.
Carl
Rich Egan
>Carl:
When you get to Wisconsin, let us know. We have several active turning clubs here.
Rich E.
CARL BARTON
>Rich,
I most certainly will do that. Thank you for the invite and I am looking forward to my retirement and lots of fun turning,ice fishing, snowmobiling and just general good fun. Plus all the Lienie's I can drink. We can not get the Dark and Creamy here in Virgnia and there has many of time that we have packed the car's trunk with cases to last us the year before we have to go on another road trip.
Carl
Rich Egan
>Carl:
If snow shoveling in your retirement is what you're looking for, this is the right place! Come on up!
Rich E.
CARL BARTON
>Rich,
I love the snow, I grew up in Idaho, 45 miles from town, 5 miles from the nearst neighbor, 7 miles to the school bus stop. Lots of land to roam around. I can hardly wait to get up that way.
Carl
