A55 Smoothing Plane
Jet Mini Help
Jet Mini Help
Jet Mini Help
Randy G
>Hello all, I'm hoping I can find some help for my Jet Mini lathe. I've been working on some chess pieces for my BIL (pics to follow when done) and I've started to notice some lateral movement on the headstock. I'm using a Oneway Chuck on the spindle and measured maybe 1/2 mm of movement laterally along the lathe as I'm turning. If I grip the chuck (while off) and pull fairly hard i can get the lateral movement as well.
I've tried tightening the wheel on the outside end of the headstock and believe I have it as tight as I can. And I don't see anything else to tighten or adjust. Any ideas?
Re: Jet Mini Help
Re: Jet Mini Help
jwoodwright
>Randy,
Hopefully this will help. The hand wheel is actually the outside stop for the spindle.
Too tight and it makes noise and gets very hot.
Too loose and it rattles and gives end play.
Have yo tightened both (2) setscrews on the hand wheel?
Do you use the hand wheel to slow the lathe?
Are you using the Oneway Talon?
In over 10 years with 2-Jet Minis, Ive learned to almost thread the chuck or faceplate on and then use the knockout bar to hold the spindle and give the chuck a "wrist snap" to lock it...
John K.
Re: Jet Mini Help
Re: Jet Mini Help
Galen V
>John K
Maybe you have had your spindle removed and know how critical the wave washer is in setting a preload on movement of spindle. I got free bearings and found a good description I saved on replacing. It cautions the handwheel has reverse threads, two set screws, and then that this wave washer is to set on a shaft lip and may drop out of postion on reassembly. Sounds like it could change preload if handwheel got too loose and wave washer dropped off position.
Jet manual sucks by saying leave a "little" space between handwheel and headstock when replacing belt and says nothing about the wave washer location. Very technical!
Wonder if bearings worn and causing lateral movement or if it is realy shaft movement only. Guess you got to see it and hear it to know. Pulled hard on chuck on my 1220 and it has no movement I can detect. Maybe check out the wave washer location?
Re: Jet Mini Help
Re: Jet Mini Help
Karl Rinehart
>Have you checked the bolts in the threaded insert on the chuck? If these are not tight, you can have some problems.
