Digital video camera with ext. mic input
>Does anyone know of a camera that is affordable that has an external mike input. I looked at quite a few this weekend, JVC, Canon, Panasonic mostly and the models they had are in my price range, about $300 to $400 but none had external mikes. I really hate on camera mikes.
Re: Digital video camera with ext. mic input
Jeff Rich
>Unfortunately, in the age of how do we cut costs....the mic input was one of the first "pro" features to go....
Sony and Canon may have an input on the higher priced consumer units.
Most Pro units will have one, although they can be salty.
Russ Fairfield
>You will have to get into the $600+ price range to find what you are looking for, but you will also have to buy a whole bunch of stuff you don't want.
Have you looked into the used market. The used miniDV tape cameras are starting to show up at bargain prices as people are upgrading to card and hard memory. Check Craigs list and the nearest big city newspaper ads. Goodwill and similar stores will also have an occasional camcorder.
Thanks Russ and Jeff
>I did more research tonight and several of the MiniDV canon cameras say they have external mike jacks. I'll have to hit the stores and play with one. I had been looking at purely digital instead of tape for easier downloading and editing but my boss pointed me toward some software that's pretty inexpensive so I'll look at the miniDV's again.
I sure did like the JVC cameras I was looking at but when you need to record in a woodshop I think an external mike is essential.
Re: Thanks Russ and Jeff *LINK*
Jeff Rich
>Always welcome!
I think what you really "need" is the JVC GY-HD250.
It is a great all around camera for field and studio.
LOL, seriously it is an awesome camera package.
JVC HD GY-HD250
Re: Take a look at this one *LINK*
Russ Fairfield
>John, just be careful about not buying too little. You should be looking at a video camera you can grow into, and not out of.
I was looking at video cameras today, and this one is impressive. Although it is double your price range, this is one of the best buys in a camcorder, it has a mic jack, and it won't be one that you will be wanting to upgrade anytime soon.
http://www.onecall.com/ProductDetails.aspx?id=92438
Rich Egan
>John:
Be careful where you purchase your camcorder. I had a bad experience with Broadway Photo out of New York. Buyer beware.
Rich E.
My old Sony DCR-HC40 has one
>It is a great little camera that I got about 5 years ago (or more?). It was more than $400 at the time. Anyhow, DV cameras have continued to evolve in that time and you should be able to find a good used one on eBay or somewhere for a very good price.
>John,
Assuming by "digital" you mean miniDV, the older Sony VX-1000 I use has an external mic input. It's an older camera, but it has excellent features and video quality (3-chip). I've used it with wireless, shotgun, and quality mics on stands. The camera was around $1000 when it was new but I think used ones are pretty cheap.
You're welcome to borrow this one if you want to try it for a few months.
>John I bought one today. A canon zr900. It has manual focus override, and external mike. It isn't a fancy camera but it looks like it might do the job. It will at least get me started.
Would zr900 work for video setup?
Ed Larson
>John, I'm looking for a camera to use in our club as part of a video set up. Would the cannon zr900 work for that?? We would feed the output to a digital projector.
Re: Ed- that Canon model would be....
Jamie Donaldson
>...fine for your application, as well as several others in that price range. With a zoom ratio over 1:30 you have many from which to select, but buy an AC power supply if not bundled with the camera. Also make sure that you have available manual focus so that the lens will not continuously auto range on a spinning object.
>Ed It seems like it would do the job but I have not had a chance to play with it. Hopefully later today or tonight I can run it through it's paces. It does have what it calls manual focus override but I don't know what that means or how it works yet. I did play with it in the store and the auto focus works really well. It focus down to 10" in the wide setting and 1 meter in the tele which doesn't tell you much but I would guess it will fill the frame with a business card or smaller. It has a fast lens and seems to work well in low light. I'll let you know more tomorrow.
Look on the net and you may be able to buy it for $200 or less.
Camera for lathe demos
>Ed,
For a more professional setup you might look into using a tiny "lipstick" color camera. The better models have fantastic optics and resolution (we used one under a helicopter for flyovers) but even the cheaper models should have more than enough quality for turning demos. The high end models are over $500 but for turning demo use, a suitable camera can be purchased from people who sell security systems for much less. These are NOT the cheap plastic cameras commonly available with cheap security systems - expect to pay perhaps a couple of hundred dollars. I saw one advertised for $89 but I'd want to check it for quality. The last one I bought for a security system was a good quality B&W model for around $150 but that was a few years back - it's in a weatherproof housing about 1.5", perfect for an environment with a lot of fine dust. Note that camcorder mechanisms will eventually choke and the tiny miniDV tapes are susceptible to digital dropouts from fine dust.
The nice thing about lipstick cameras is they are so tiny and lightweight they can be mounted on a light weight stand or flexible arm for positioning right over the lathe where the action is. They are NOT camcorders but if you need to record just connect a recorder downstream. Most camcorders need to be mounted on a reasonably sturdy tripod sitting on the floor or a table which severely limits placement.
I think just as important, a lipstick camera is so small it will be unobtrusive regardless of where it is positioned.
The lens on the lipstick cameras I've seen (and the one I have) is fairly wide angle with a deep depth of field for easy focusing. I set one up on a lathe to test it once and I was happy with the results (and as a former video professional I tend to be pretty picky!)
I recommended this to our club but the guy ended up buying a camcorder instead. Unfortunately a problem showed up when we started using it to feed the monitor (not for recording): after a few minutes of being turned on but otherwise inactive the darn thing goes into a demo mode and starts showing all it's wonderful features on the screen! Someone has to run up and push a button on the camera to get the picture back. Very distracting. (Perhaps this behavior can be overridden but I haven't looked at the manual.) Be aware that some camcorders automatically shut off after a period of inactivity which would also interrupt the demonstration.
The ideal setup would be two or three of these tiny cameras, each on flexible arms, and connected to the monitor through a video switcher so you could switch between say a long shot, closeup, or straight overhead by pushing a button on the switcher.
Re: Camera for lathe demos
>John Although I like the small mini cams I think at least one camera should be a full video camera. The reason I say that is every demo is different and having a camera that can easily be moved and zoomed in and out is very important. I thought Jamie's method of using 2 mini cams and one roaming Video cam worked great.
I heartily agree with your comment about the way some of the cameras work by cutting out early, showing menu's etc. It's irritating. Unfortunately the camera descriptions don't mention this at all. I looked all over the internet and basically there is very little info about what really matters to me on cameras. I thought you could download manuals and search those but I had a very hard time finding any of them and then they don't give you all the info. You must have your hands on the darn things and play with them to find out how they really work.
