Lathe finally in the new shop...
Ned Bulken
I still have to bolt it down, once I get the other bench fully assembled, but there is my midi IN my shop finally.
Ned Bulken
What did you repair the bolt hole with?
steve antonucci
Re: What did you repair the bolt hole with?
Ned Bulken
>Haven't yet, just moved it into the shop. I still have to finish assembling the bench I'm going to bolt it to. I may just got with three and see how it behaves.
Re: Lathe finally in the new shop...
Mike Rubes, Apex, NC
>Hi Ned,
Excellent! Glad it is in your place. Just curious, and I may have missed the posts about this, but what is your new shop? Is that a garage or a stand alone building you have there? Any exterior shots or more interior shots?
I love to see other people's work environment, it invariably gives me ideas about my own and how to improve it.
I hope all is well up there, we are plenty wet down here right now, but nothing but a steady drizzle all day.
Mike
Never enough hours to turn what I want in Apex, NC
Ned Bulken
>Mike,
I just posted a major shop update over on the general messageboard today, but to answer your question, it's a 12x20' 'mini-barn' (so called by the folks at barnplans.com, where I bought the plans). 10' sidewalls gambrel roof, built on cement piers on top of gravel. Stand alone out in the middle of my back yard behind the house.
and just to prove it really does work:
Texian
>Ned,
Looks like a dandy new shop building. Now would be the time to think about wiring, insulation, and maybe frame in an opening for small A/C/Heater unit. Don't know the climate of your location, but have noticed that what most visitors to my shop like best is the A/C. Just a thought.
Ned Bulken
>I'm doing this on the proverbial shoestring, so wiring is 'next' after I move in. (yep it would be easier the other way around, but $ for storage unit takes away from wiring budget...)
I Have two window rattlers, need to test that they still work, but if one of them does, it should more than suffice for my 240 sq ft space. I also have a heater which will go out there in the appropriate season. Insulation and then wall treatments to follow as well. one step at a time, however.
Oooooohh...
Don Orr
>...lathe chips in the new shop, now that's what I call progress.If you get to turning you might not get the shop done though.
That's the way to do it.
Clem Wixted
>I read quite some time ago about a college that put up some new buildings. They didn't make any sidewalks for a year. After the year was up they put sidewalks where the students had worn pathways. Makes sense.
You might find the exact spot to put everything before you make permanent installations.
I have a 12 X 18 room for my shop and it is amazing how much stuff you can get into that space. I wish I had put quad outlets instead of duplex and put more than one 220 outlet on each wall. Also wish I had put more of them up higher.
I wouldn't want to take everything out to make any changes now :-)
Clem
Re:Money for Nothing...?
Ned Bulken
>Clem
I think I visited that college, back when I was a road warrior photographer on the fraternity/sorotity photo circuit.
Honestly, I've had a long time to think about layout and tool placement. Last winter I was pretty well limited to working on the computer on that. The lumber rack is set, unless I rebuild it to hold more stuff, my benches should go near the windows for natural lighting... so outlets near each of those, and so forth. The TS will have a parking spot since it has wheels (herculift). As for the rest, bandsaw ought to go near the lathe, etc...
You're right, however, it will change, many times over.
