Damaged Lathe
Ned Bulken
>I moved my lathe into the shop last night. In the process of doing that, somewhere this weekend, it must have gotten dropped on the left rear corner. NOw I only have three points to bolt it down, but that should be enough to keep things stable. If worse comes to worst, I can always drill a hole in the side of the casting, and bolt it to a board which I would then lag bolt to the stand or bench (depending on which I decide to use). It's only a midi, so I won't be spinning anything Too huge after all.
