THE WOODRAT IS BACK!
PM-90 Risers
PM-90 Risers
PM-90 Risers
Roger
>I have a chance to buy a good solid Powermatic 90 lathe for a reasonable price. Does anyone have a source for info. on risers for this lathe to raise the turning diameter capacity? Thanks.
Roger
Re: PM-90 Risers
Re: PM-90 Risers
Sean Troy
>I don't have any info to help with the risers but try and post on as many turning forums as you can. I see talk once in awhile about the 90's and people seem very happy with that lathe and find ways to install risers. Good luck, they are great lathes.
Re: PM-90 Risers
Re: PM-90 Risers
David Walser
>I've always heard people say they got a local machinist shop to make and install the risers.
Re: PM-90 Risers
Re: PM-90 Risers
wilbur
>I considered doing this for an old Walker-Turner lathe that I have, to try to increase the capacity from 10" over the bed to 12". Theoretically, it's pretty straight forward for a machinist to do: mill out a piece of steel/aluminum 1" thick (gives you a 2" increase in swing), and then drill holes for mounting, using whatever mounting holes are used for your headstock. Do the same thing for the tailstock.
However, in practice, I found this not to be as easy. The machining was not an issue -- I was taking an evening machine shop class at the time, so I had access to the equipment, and this type of job is pretty easy for any machinist. The problems I found were with the other parts of the lathe. I would have had to change the belt, since the headstock was going to be in a new position, and that meant disassembling the headstock. I would have had to get new tool rests, since the posts of the tool rests that originally came with my lathe would have been too short. Also, the reach of the banjo was such that if I had mounted a 12" round blank, I would not be able to access all of it with that banjo, and even if it was long enough, the banjo didn't seem thick enough to give me a vibration-free cut.
These may not be issues with a PM90, but I'd check these things out first. In the meantime, I'm still using what must be one of the heaviest duty mini lathes in the world. :@)
Re: PM-90 Risers
Re: PM-90 Risers
Bob Ballard
>Roger,I've got a bowl lathe that I made from a 90 with a broken way.I shortened the bed to 28 1/2".I raised it to swing 20" and later to 24"and added a frequency drive.20" was fairly simple,24" much more difficult.
What do you need to know?
Re: PM-90 Risers
I say think it over
Eddie Pacheco: San Jose, Ca,
>I had one of those and sold it last year. It was a great lathe in it's time, but I just didn't find it so user friendly for wood turning. Metal spinning and spindle turnings no problem with that late. It certainly was designed for the time when men were men that's for sure. I now have PM3520 and it is WAY more versatile for wood turning. Like I saw, just think it over and how much you'll have into it by the time you add the risers and VFD along with a new motor.
Re: PM-90 Risers
Keith Tompkins
Re: I say think it over
keith tompkins
>When men were men? NO wonder I want one so bad!! Thanks for a good laugh Eddie!
Re: PM-90 Risers
Re: PM-90 Risers
Roger
>Thanks for all the input.
Roger
