Any lathe news from IWF?
wilbur
>Just wondering if any woodturners here went to IWF, and if there was anything new on the lathe front.
wilbur
how about Oneway CNC? *LINK*
bob elliott
>Did not go but Oneway was supposed to be there, in a slightly different capacity!
Oneway CNC
Re: Any lathe news from IWF? *LINK*
Dick Coers
>Steel City had a prototype of a granite mini lathe. Granite bed, granite head stock. John Lucas talked about an update on the Delta Midi, but I missed that. There was a nice setup of a Nova with their decorative turning attachment, but that's not new. Legacy is adding CNC to their basic ornamental milling machines, and making a new machine that will work on flat stock and turning. $33,000 for the small one!!!!! The Oneway CNC is a dedicated machine, but I was really confused on the software. If I understood the heavily accented English spoken in a slightly noisy isle, Oneway does the Gcode writing then charges you based on the number of parts you make? Something like that. Picked up some abrasive balls from Performance Abrasives. They call them Scuff&Buff ball. They take a pack of wavy cut scotchbrite and fasten them on the end of a hex shank. 60, 80,320, 600 grit, 2",3",4" diameters, 2.4, 3.5, 5.5 long shafts. Nothing on their web site yet.
Legacy Phantom
Delta had the Midi...
>and it looked very good. It is 1 hp, VS short bed lathe. Sort of their response to the General Maxi. It looked very good and felt rock solid with the leg set that they had on it.
Steel City had a lathe that essentially looked like a Nova - but Teknatool was sharing the booth, so it probably was. I didn't see if Oneway had a booth.
Jet/Powermatic was there - but no really new lathes.
I was only there for one day, so I didn't look at everything.
Pretty slick machine
>It's essentially a CNC driven, three axis router mounted to the rear of a spindle lathe. You choose the desired program, input some data, and turn it loose to create all sorts of 3-D designs. They've already pegged it for decorative table legs, and I can see some other nifty possibilities, too. The quality of the surface this machine produces is really quite remarkable, depending of course on the sharpness of the cutter and the species of wood. The legs we looked at were amazingly smooth.
I didn't hear anything about paying per the number of pieces. You own the software (which has a pretty nifty user interface, by the way), so I would think you can program it to do anything you like. Contact Kevin Clay for more details. The mentioned price was in the 20s.
Re: Pretty slick machine
Dick Coers
>Here is a quote from the Oneway web page;
"Design Work" and "WatCAD" are web based application that take user choices and convert them into graphical models. The user can preview, edit and verify the model. The user does not need to buy a CAD package. Once a graphical model has been built it is used to produce tool paths. The tool paths are calculated on the server using proprietary software. The user does not need to purchase a CAM software. In our method the user does not need to buy software."
I read that as you don't have a CAM package. I assume that it would cetainly run on G Code, but you don't get that type of package from Oneway.
Steel City
Ralph
>The reason Tim (Teknatool) was there is a Steel City lathe coming to the market with a Nova DVR-XP head stock
Granite lathe, Nova decorative setup
![]() Here's a shot of the manual speed-change version of the Steel City lathe. They also will be offering the same lathe with two-belt-range variable-speed control. Granite is proving to be a very good engineering material for all these Steel City machines. It is heavy, ultra-stable, cost effective, super flat and it doesn't rust. So far they have had negligible returns because of chipping or cracking of the granite, so the long-term usage prospects are looking good.
Ellis |
Re: Granite lathe, Nova decorative setup
wilbur
>Although I do think that granite is a great solution for things like machinery tables and fences, and that I don't think that bouncing things off of them will cause any significant damage or affect how they work, I do wonder about its durability in a lathe. I'm thinking of the times that I've bounced a gouge off of a lathe after a catch, or the impact of a rough blank on a turning tool as you're trying to knock the corners off of it. The gouge bouncing to me seems to be a much greater impact force on the lathe than dropping a hammer on a jointer table, and the repetitive impacts from roughing the corners off of a bowl blank could quickly add up to the number of impacts that a granite bandsaw table would take over a quite a long period of time.
Still, I'm looking forward to seeing these lathes.
>I think Steel City missed the boat on this one. Sure it has a granite bed but it's still a 10" swing non portable mini lathe with a 1/2 horse motor. It's nothing special other than the bed. I think they should have made it 12" swing and 36 to 40" between centers to take advantage of the low vibration of Granite. That's why they originally made the wooden bed lathes was to absorb vibration. I think what people want in a mini lathe is either quality at a low price, or more power so when you do demos on the mini and your used to a Oneway you don't have to sacrifice so much. That's why I think the new Delta will be a big seller.
