>I turn a good number of pens, keychains, etc. for craft shows. I work mainly with exotics. For the longest time I have been wearing a respirator while turning, which gets hot and heavy when working for several hours at a time, but necessary with all the dust created.
Until now...
I finally got around to hooking up my dc to my Jet mini using a clear hood from Rockler. I mounted the hood bracket to my lathe by using several high strength magnets. This makes the hood instantly adjustable...just slide it left or right as needed.
The hood has a flip up shield that I use in the down position for turning, but flip up for sanding. When the dc fires up, 90% of the chips from the dry exotics get sucked into the dc hose, along with just about all dust. Even with the shield up for easier access for sanding the dust just disappears. I can't remember even a sniff of dust, even when working with cocobolo, wenge, etc. You can see the dust being sucked in.
In short, this little gizmo works! I can't imagine turning without it. The only real cons I have found are the constant blast of noise from the DC which I turn off and on with a remote as needed and wear ear protection, and the problem of mounting the bracket. Like I said, the magnets solved the problem of having to drill, tap, etc., and makes the hood easy to adjust.
You could make something similar, but, for $19 or so on sale, it's not worth the time and trouble. If you watch, it is often less than the current sale price.
>I need to point out that this hood works very well with my small stuff...pens, keychains, egg kaleidoscopes, pocket watches, tea light holders,... Logic says that if the item you are turning is larger than the hood, and that the hood can not be pulled over the object you are turning, you are expecting more than is promised by the accessory. For small turnings, this hood is super.
One tip...spray (don't soak) the inside of the hood with some anti-static laundry/ironing spray every now and then. This keeps the dust from sticking.
>I use this hood in conjunction with my Fein Turbo II vac for dust collection, but only when sanding. I tried using rare earth magnets to hold it to the lathe bed, but it kept sliding around and was a huge PITA for me. I now just slide the connection bracket between the ways and connect it to the vac. This combination works very well for me.
