scraper blade
Paul Zerjay
>I'd like to make a scraper blade for the inside of hollow forms from an old worn out jointer knife. Anyone ever try this? I'm having problems drilling a hole through it in order to fasten it to my hollowing bar.
scraper blade
Paul Zerjay
Re: scraper blade
>Paul,
Since that steel is hardened, it will be difficult to drill unless it is heated and annealed, but then it would have to be hardened again and tempered after drilling.
Have you seen the teardrop scraper shapes sold by Sorby for use on their multi-tip shear scraper? I use them on Sorby's tools but one could easily be fastened to your hollowing bar. There are two sizes, as far as I know.
Re: scraper blade
Jim Pugh, Elyria, OH
>Another suggestion is to take a cutoff wheel on your dremel type tool and cut a slot to the center. Make it slightly wider then your screw. Slip the scraper on under the screw, turn it the direction you want and tighten the screw. It works for me.
Re: scraper blade
Paul Zerjay
>John
I saw those, but I didn't realize they came in two sizes. I guess I saw the larger one which in my opinion is a little large to fit through the opening in a hollow form. Thanks for the quick response.
Re: scraper blade
>I went out to the shop and measured mine: the large teardrop shape is about 27mm at the widest point; the smaller shape is about 18mm. They also make a 24mm round shape.
If the small one is still too big, I suspect it would be easier to start with it and grind it smaller than it would be to make a reasonable hole in a jointer blade.
Re: scraper blade
Ian
>Paul, this may work. I have used this method on other hardened steel.
pick up a 3/16" masonary bit, and using a drill press and high speed drill thru the planer blade, as you apply pressure the blade will glow red before it acually cuts thru. What you are doing is spot annealing the drill hole.
I use a wood backer block, and the drill bit may do two holes before being junk.
as I said it has worked for me in the past.
IAN
Re: scraper blade
galen V
>Being a novice wood turner your question made me wonder if the replacement wheels for a pipe cutter could be used as your scraper. They are hardened steel, already have a hole for mounting, and can be purchased in sizes from like 3/8" to well over 1 1/4". Cheap! Since they have a double bevel would be more like a skew used as a scraper or shear scraper?
It seems I should have kept tooling from my old South Bend metal lathe as a lot of woodturning tools I see now are actually HSS and carbide cutters I used then. Well guess I cannot keep things forever, but sure cost more to buy again.
Not sure what you all think about the pipe cutter wheels. Too crazy?
