Tormek Jigs on Dry Grinder
Dan Faux
>Hi All
As all of my Turning Tools are so far from "The Ideal Grind" I was wondering if anyone has adapted the Tormek Jigs to work on a normal dry grinder. I have an extra universal mount so it would just be a matter of mounting it."wouldn't it"???? and the regrind prior to sharpening would be so much faster.
Dan
Re: Tormek Jigs on Dry Grinder
Bill Noce - Jefferson, Ohio
>Dan........I have seen somewhere on line that someone had done just that and it worked good. But I don't remember where. If I find it I'll post a link to it.
D Parrillo
>On the last page of the March 2007 WOODTURNING magazine, you will find an article on that topic.
Dan Faux
>Thanks Bill
I knew I had seen that article but couldn't remember where and many thanks Donna you saved me hours of looking for it.Much appreciated..
maybe that Aussie gymnastics judge should see how nice Americans are on this board.....enough said
Dan
>Thats where I saw it..........
Ronald Nelson
>Dan,
I posted my setup for using Tormek jigs on a dry grinder some time ago here on WC. It works very well. The Wolverine jigs are on the grinder as well because I use both methods when teaching sharpening of lathe tools at my local Woodcraft store.
The pedestal height is 7 3/8 inches with the 3/4 inch spacer under a Woodcraft grinder. Note that the guard had to be cut back slightly for clearance.
Let me know if you have questions.
Ron Nelson
>Ron,
Were you able to buy the tool support rod mount or did you salvage it from a Tormek?
Ronald Nelson
>Hi John,
The Tormek parts are available separately. The horizontal mount (XB-100) is a retro fit for older Tormek grinders. I happened to get mine at a Rockler store. The Micro Adjust Universal Support is Part no. US-105. Both items are also available at SharptoolsUSA.com. Look under replacement parts/ upgrades ans replacements.
Instructions for using Tormek jigs are available as a free download at Tormek.com or you can buy them in printed form at any Tormek dealer.
Ron Nelson
Dan Faux
>Great setup Ron, I have the bar and the holder and I hope you don't mind me copying your design.
>Thanks. I have the Tormek, all the jigs, and a couple of extra tool supports and have wanted to adapt the jigs to my dry grinder for some time. I was going to make a bracket but buying one would be a lot quicker!
