Smude Pot box
Smude Pot box
Smude Pot box
>When I took the Ray Key workshop I made this little hollow vessel. The wood was ugly so I painted it. I liked the paint but it was missing something. I thought it looked like one of those Smudge Pots that they used to put on the side of the road as markers back in the 50's with flame and smutty smoke. Therefore I made a lid for this vessel that resembles a flame.
I sold it when I walked in the door at work this morning. I guess I need to raise my prices.
Re: Smude Pot box
Cupcake with Cherry on top
>This is my latest cupcake with new icing. I tried modeling paste. It seems to work but adds a lot of moisture to the wood and makes it move. I left finish off of the lid where the icing goes so it will grip better but I guess I'll have to apply a finish and then rough it up with sandpaper.
Re: Smude Pot box
Gavel
>Here is the photo of the gavel I made with the cut out feet on the striker base.
Re: Smude Pot box
Re: Smude Pot box
Sean Troy
>Nice work ! You've been very busy.
Re: Smude Pot box
Re: Smude Pot box
galen V
>My step-dad was a railroader and believe me it the smudge pots looked that good my mother would have them all collected up and on a shelf.
Very nice!
Re: Smude Pot box
Re: Cupcake with Cherry on top
don lewonczyk
>Cherry looks good enough to pluck off and eat it. John try a scrape piece of wood with your finish on it and without sanding the wood to rough it up apply your modelling paste and see what happens, I believe it should stick. I have used paste over sanding sealer because of the water in the paste and it stayed on with no problems. Your smudge pot looked real cool, as always nice wook. DonL
Re: Smude Pot box
Re: Smude Pot box
Michael Stafford
>I remember those smudge pots. I think this might be the best looking smudge pots I have ever seen.
Your cupcakes look good enough to eat, John.
Never turned a gavel but yours looks great.
See you Monday!
Re: Smude Pot box
Re: Smude Pot box
Ron McKinley
>When I was a kid we called them "Flambeaus". Don't know if that was the name of the company that made them or just what they were called.....Ron
Re: Smude Pot box
Re: Smude Pot box
Michael Stafford
>Ron, I remember them being referred to as flambeaus as well. I haven't seen one in many years.
Re: Smude Pot box
Dick Hines
Re: Smude Pot box
Dick Hines
>I was hopeing I would never see another one. When I was in high school I worked for VDOT and we would have to clean them between uses. It was not the best job I ever had.
Re: Smude Pot box
Re: Smude Pot box
galen V
>Mabye this is not what your turned piece is representing, but it is what you made me think of. I use to kick these over in the rail yard as a kid and get yelled at by the yard master.
Re: Smude Pot box
Re: Smude Pot box
charlie belden
>Since no one else has asked yet - more details on the "flame" please.
Outer "flame" cut in half after somehow hollowing? Looks like the coved element below it is an integral part of the outer flame so probably not hollowed from the bottom. That leaves hollowing from the top, hole covered with the flame "cap".
How'd Ya Do Dat?
charlie belden
ps - they're still using smudge pots in Panama
Re: Smude Pot box
Re: Smude Pot box
>Charlie It is called inside-out turning or involuted turning. The simple explanation is you take 4 pieces of wood that are perfectly square. temporarily fasten them together, I use a paper joint. Turn 1/2 of the flame pattern. Then you break the glue joint, reverse all the pieces and glue them together permanantly. The 2 -1/2 flames form a flame silhouette when glued together. now you turn the outside.
The advantage of this method over simply hollowing and piercing is that you can put things inside. I glued up 2 of the 4 pieces and then placed the yellow heart flame inside and glued these pairs together to make the blank for the final turning.
If you google inside-out turning you can find instructions. If not simply e-mail me and I will send you my hand out on turing and ornament using this method.
