Have a question? Ask Woody!
Chargers, sorta OT...............
Richard Jones
>Sort of OT because it doesn�t really involve turning, but turners may have better insight into this than others, so������
My S-I-L wants me to make some chargers for guest plates at her daughters� (my niece) wedding next summer. But instead of turning them (thank you, Lord, for that), she wants me to slice them from the entire stick of wood. They had to take a pine down in their yard to accommodate their barn relocation, so she wanted to make them from that for sentimental reasons. Pine isn�t quite the sentimental favorite of mine, but, hey, who am I to stand in the way of sentiment��
Anyway, was just planning on slicing them up about 1� thick on the BS, and I can do about 11� including some sort of sled. She's told me that if it didn't work out, nothing lost, but I told her I'd take a whack at it to see what happens, so thought I would at least do a 1/2 dozen or so as prototypes.
Any thoughts on this, i.e., drying, cracking, splitting, bark (of course she wants the bark on!!), finishing, handling the sap, etc.?
Many thanks, hope everyone has a great day.
Rich in VA
Re: Chargers, sorta OT...............
Don Orr
>Sounds like a nice idea but I think you will be hard pressed to keep them from splitting. Supposedly if you soak them in PEG when green they will stabilize. I don't know where you can get PEG anymore though. In the arborculture community these slices are referred to as "cookies". PEG is polyethylene glycol-a thicker relative of older style antifreeze and commonly used as a bowel cleaner for colonoscopies.
Hope it works out for you.
What is a "charger"?
adrien------WebKitFormBoundaryCYgCTS8iAM5FYG+w
Re:Don't they play out of San Diego?
Dave Anderson (PacNW)
Re: What is a "charger"?
Barbara Gill, Remlik VA
>A charger is a plate you put a plate on. They are usually decorative. The pieces will split but most likely not right away. Slice them fairly close to when they will be used and don't put them on a wood table unless it has poly on it. The moisture from the pine will go right through the tablecloth. I don't have a good solution for the sap. :-)
BTW, How Many Will You Need?
>>...I don't have a good solution for the sap. :-)
I understand kiln operators heat to some specific temperature to set (harden) the sap. From Dr Gene Wengert on the forestry forum: "We suggest no cooler than 160 F and 180 F is better." Another person suggested putting wood in the attic for a week in the hot summer.
The PEG is 1000 weight.
Keith Newton, LR, Arkansas------WebKitFormBoundary
>And the temperature will set the resin by evaporating the volatiles.
It might also be a good idea to saw across as an angle like 45� rather than 90�. this gives the difference between R & T another way to relieve itself, although I would still expect there to be a hump or dip in the juvenile wood after it is fully dry, but you should be able to flatten again after that.
Sell them on the idea that the elliptical shape gives a place for silver, or is just more creative than round.
Bill Grumbine (Kutztown PA)
>At least she wants chargers, and not trenchers! Of course, if they end up as trenchers, and you use PEG like Don mentioned, all the guests will be as clean as the proverbial whistle. ;-)
>But if you dry those discs they will crack.
art opportunity
Maybe this is a design opportunity. Make several radial cuts in from the outer edge before they dry and crack on their own. As the wood dries, the kerfs will widen. Call it art.
Re: BTW, How Many Will You Need?
Richard Jones
>B,
Not sure, but I'm guessing 100+............
R
Thanks for all the responses.....
Richard Jones
>I may try a few in the attic to try and "set" the sap, but agree that may hasten the inevitable checking/cracking. Maybe they will ALL be design opportunities...........
I appreciate the help and the consensus. I wouldn't mind the splits too much, just hope they'll stay relatively flat after I cut them.
Will keep all posted, if interested..............
Thanks again.
Richard Jones
Rice, VA
Good Idea John
Along The Same Line
>Shortly after I started running a sawmill I cut the end off of a small Spruce Pine log, diameter was around 8" Just for the heck of it I put it up on one of the framing cross members in the mill. I looked at that little round piece of wood every time I came into the mill. After about 5 years of smugness on my part (see not all end rounds will crack) I came in one morning and the thing had cracked all the way to the pith.
Barbara............
Richard Jones
>Maybe I'll try using a Forstner bit to remove the pith, just as an experiment. Then they can be holey chargers...........
Good story, and just goes to show that we're really not in charge, are we?
Hope you have a great day and pray you have some rain. Getting very bad here...........
Rich
Re: Barbara............
>Another interesting idea. Last week we got a couple of nice storms thank goodness. I was hoping for several days of rain from Fay but not now.
have to be round?
>Any rule that chargers must be round?
If you have enough log: What about rough-sawn planks (with bark left on the edges) instead of rounds? You could chainsaw to length first (with no attempt at smoothness) to leave interesting ends, then endcoat before sawing the planks. To minimize warping, bundle between stickers with clamps (or significant weight) and dry in a warm place. A buddy with a woodmizer could saw these in a few minutes.
Or if you go with the forstner holey idea, a number of randomly placed holes (in varied and interesting sizes) might help relieve the stress.
I thought of another thing which would slow cracking on rounds. If the entire round is well sealed with something (I don't know what), most of the moisture might not escape by the time of the event and the pieces should stay green and together, at least for a while.
