Tailstock - PM 3520B
Nick Tuzzolino
>When pulling off the tailstock, the last few inches (the problem started with the last four or five inches) are extremely tight. I have to jiggle and juggle the thing off. I lowered the lock ring as far as possible, filed under the ways in case of tiny burrs. Called Powermatic, but they suggested the same as I've done. This all improved it some but not completely. Any ideas?
Re: Tailstock - PM 3520B
>I just looked at mine so I had a fresh idea of where the parts are. The first thing I would do is try to narrow down the problem.
Is it binding as you remove it, or binding on the last few inches of travel down the bed. If it's binding when you try to remove it that's kind of natural because any twisting motion cause the front tabs to bind. I wish they had made the front tabs about 2" long and moved the clamping mechanism back further but they didn't ask me when they designed it. :):)
If the tailstock slides nicely in the middle of the ways cut a short board about 4" long and then plane,file, or sand until it just fits between the ways in the area where the tailstock slides freely. Now slide it toward the end and see if the problem is in the bed ways themselves. If the problem lies there you should be able to tell exactly where it is binding.
Once you've narrowed down the area check both sides with a straight edge to see if you can tell if one side or the other has a bulge or if they are bowed. This should tell you which side needs filing. You can probably lay the file down lengthwise with the bed and file the bulge spots that way. I did this on my table saw because the miter gauge slots were not perfect. It takes patience but it works well. It's probably off just a thousandth or less so file a little and check it.
I doubt there is anything wrong with the tailstock itself because it's just 2 cast tabs, one at each end. If you file these it could throw it off when it's on the free'er parts of the bed.
Nick Tuzzolino
>Thanks, John. Sounds like a good plan.
