thin walled bowls
BQ in VT
>After having a crappy day - 3 bowls went south on me, I am turning to you knowledgeable folks. I turn thin walled, 1/16" +/-, bowls. I have problems getting the walls a consistent thickness. I am also having the tendency thses days of turing the walls to thin, usually so that light passes through and the rim will be much thicker. There is the ever present danger of a catch when the bowls are that thin. I had that happen today also...Things usually turn go terribly wrong when trying to make that "last cut" to try to fix some of the aformentioned problems. I am in a rut (no fun) and any advice would be greatly appreciated. As always, thank you in advance.
