Limits of a Jet 1220?
galen V
>Now that I have turned a few green bowls on my Jet 1220 3/4 hp I wonder how I really determine if I am shortening the life of the unit by the size and weight of the green piece. Are my goals bigger than the machine? I use a talon screw in the chuck and initially support with tailstock. Blanks are cut to rough round by plywood templates on the band saw. Largest was about 9 1/2" dia and 5" thick. Run at lowest 500 rpm speed. Wet heavy piece but did not weigh. Balance was not too bad and Jet steel stand weight seemed to keep steady. Belt not slipping but then that doesn't mean it is not taxing belt. Motor does not seem to get too hot but no temp indicator to be sure.
Can experienced turners give me some indication of when piece is too big for this lathe? Just because it has a 12" swing it may not be practical (wise) to every try a green bowl blank up this large. Any practical way to set limits? Yes I'm green too!
Re: Limits of a Jet 1220?
Keoni
>I also have the Jet 1220 and have been turning without any thoughts about stressing the lathe. I have turned several NFP's at least 11" diameter to clear bed. Other hawaiian wood also. Still looking to adapt the mini McNaughton center saver if I can find a banjo with a 1" post to fit the bed of the 1220. For the price of the lathe I put any worries aside. The satisfaction of turning is well worth it. If it breaks I'll get a larger one, so for now I'll enjoy what I have.........
Steven Antonucci
If you have to move the lathe back to its spot
steve antonucci
>It might be too big :-)
Seriously, I don't think you have too much to worry about- a 12" lathe swing is only going to allow you to mount so much wood. Do your best to get it round first, and then finish rounding it on the lathe. I can usually true a disk from almost round to round in 2 passes.
After that, it runs perfectly smooth, so there's nothing to worry about.
Steve
Greg Haugen
>Here's a bit of information. You can buy a Oneway 1224's banjo and along with a stop block made to fit the ways of the Jet. I know several people that have other lathes and Oneway banjos. If they have the "matching" swing in one of their lathes, it can be done. 14" lathes would not be able to.
You're a brave soul trying to core on a 1220.
Good Luck!!!
Greg H.
Re: If you have to move the lathe back to its spot
Greg Haugen
>The only "dent" in the armor of the Jet 1220 I see is the 5/8" tool post. In a previous post, I mentioned an option to change that. I wouldn't worry about the bed, the bearings, the belt, the headstock, etc. In my opinion, and it doesn't mean anything, 5/8" tool post is too small for the possible torque from a bad catch on a large piece of wood. I have a 1220 and think it's great. That's the only issue I see with it. Companies are giving a larger swing but not changing the banjo.
my 2 cents.
Greg H.
Don't "baby" your lathe...
Peter Teubel
>For that lathe, bearings are cheap and belts are consumable items. Jet motors, from my experience, are pretty tough. I had a 1236 and would run that lathe HARD...so hard, I'd get a 2nd degree burn from the motor housing. Always expected the motor to die a smoky death and even picked up a spare motor just in case. Never had to replace it, though.
If you're chasing the lathe around the shop, *THEN* you're exceeding it's capacity.
Thanks for Jet 1220 input
galen V
>Thanks for your comments.
I did little research before buying but it looked like a good starting point and reasonable cost sitting at local Woodsmith Store. Sure held up to my self taught turning and errors so far. Just hate I always abuse tools to some degree.
Greg, per your comment, I read OneWay add on banjo and guess it explained the "soft" feel I get trying to lock the Jets down. It just fells like it is not tight and never having locking handle at same point. I have had a bad catch on tool rest and 5/8 post held up so far. Just hard to stay locked in place withit's lever.
Not sure about turning larger green bowls anyway as so far I feel I never get anything finished. Lots of nice long shavings but I still like to see an end to a piece!
Re: Cheap Bearing Story
galen V
>Jet (WMH Toll Group)appear to be a good group dedicated to helping a new turner. BUT they are a little unorganized! Live center bearing fell apart in one month and though probably a consumable, they did think it should have lasted longer. In sending me new free replacement they first sent both the headstock bearing by mistake. Told me to keep them too at no cost. Their shipping group then crossed shipments to wrong destinations. A guy in Tennessee got my live center and I got his metal lathe coolant pump in Iowa. Told me just to keep pump too!! I finally got free live center in the end.
Wish I new of a guy in need of a coolant pump as it is collecting dust and I hate to throw anything away.
Ken
>In response to using the McNaughton coring tool.My 1st lathe (still have it) is the Ricon mini.I got the coring tool and had the post turned down to 5/8 and cored several bowls on it,but it was a bit of a strain on it,so I got the Nova 1624 and don't try coring on the mini anymore.If anyone is interested in this post email me and I will either sell it for what it cost me, plus shipping or make a wood trade.It cost 25 bucks to get it turned down.
1236 Banjo?
Ron in Drums PA
>I've been wondering if the banjo from a 1236 would fit on a 1220.
Does anyone know the bed gap of these two lathes?
You can buy the parts to make a 1236 banjo for about $30 - $50 or so 1236 parts
BTW here's the link for Oneway Banjos
Rob Wallace
HEY GALEN! Where are you?
Rob Wallace
>Wondering where in Iowa you are.....???
FYI - We have turning clubs in Des Moines and Ames, and both meet monthly. Always happy to have more turners at our meetings!
Hope to meet you some time - good luck with your 1220!
Rob Wallace
Re: HEY GALEN! Where are you?
galen V
>Rob
From Ames, Iowa and was standing on main street watching you turn a bowl. I went home that day and added the shaft collar and thumb screw to the tool post to be able to rotate tool rest without loosing the height. Not having the tool rest you had of round rod I cannot use it in some cases due to less support height under rest but it still helps me be more consistant with tool presentation to bowl if I stay at same height.
Would be interested in Ames turners group if they are open to a novice turner. Web site seems to run behind actual activity dates.
Brian Simmons provided good help until he left the Woodsmith Store. His videos on turning pens and bowls were one of my first training references.
