Soldering iron/torch kit also wwodburning
don lewonczyk
>I see Harbor Freight has a soldering iron torch kit for $26.99 with several tips. I have a ECG J-500 model and they run on butane so you will have an open flame and (WARNING) don't use it near your wood shavings as mine gets to 2500degrees F in about 30 seconds. Great for small details and fantastic for your signature on your work, just have to be careful using it. I hesitate to give out info like this because there are always sloppy people out there that don't pay attention and get their sorry butts in trouble and want to blame someone else for it. If you fall in that catagory don't buy one, use what you were using. The benefit of this is its gas fired and uses no electric so its portable and simple to use. The item # for HF 94903-5BRA. THe tip gets hot like a regular woodburner would do, you don't have a flame shooting out the end. DonL
