grizzly lathes
grizzly lathes
grizzly lathes
bq in vt
>I am thinking about upgrading to a heavier lathe at some point in the near future. has anybody used or heard anything good?bad about Grizzly lathes? With Grizzly, it looks like your money would go about twice as far, but as with everything, you get what you pay for. I have used some grizzly tools and found them to be ok, but i have not used and not heard anything about the lathes, so any info would be great. Thanks in advance for your time.
Re: grizzly lathes
Aage Rendalen
Re: grizzly lathes
Aage Rendalen
>Grizzly is not a problem provided you get variable speed (if you're going to turn bowls), at least 2hp and adequate swing (16-20").
Re: grizzly lathes
Re: grizzly lathes
>Grizzly lathes have a slow speed that is higher than many other lathes. This makes it hard to turn rough our out of balance pieces. Be careful of the spindle sizes. They have several lathes with an odd size spindle making it hard to get accessories. Stick with 1" x8 or 1 1/4x8 and you'll be safe there.
Most people I've talked to have been reasonable satisfied with the grizzly lathe until they stepped up to a better quality lathe. I think the general consensus is that you get a lathe that is probably worth the money but not an exceptional piece of equipment.
The really inexpensive lathes are not very good but the $300 on up aren't bad.
Re: grizzly lathes
Rob Wallace
Re: grizzly lathes
Rob Wallace
>bq:
I have seen the recent 'line' of wood lathes at Grizzly's showroom in Muncy, Pennsylvania; I was not quite underwhelmed, and was not overly impressed. As some folks have commented previously, some of Grizzly's spindle sizes (e.g. 1" x 12 tpi) are non-standard sizes for most aftermarket lathe accessories, having many options eliminated because of this unusual threading. Grizzly seems to have cleaned-up its act on this problem a bit, offering 1"-8 and 1.25"-8 sizes on their newer machines. Some of the lathe stands are made of sheet metal (not likely too heavy) and if vibrating, could potentially be a major PITA with noise. The machining/finish on the cast items (i.e. ways, tailstock, toolrest) in general wasn't too bad, but lacked the refinement of higher end lathes (even ways on Jet and Penn State lathes are considerably smoother than those on the Grizzly machines I saw).
What worries me most about the 'deluxe' Grizzly lathes is that some Rocket Scientist decided it would be good to put a disk sander on the outboard side of the headstock. This eliminates any version a handwheel (which I find almost a necessity, not just a convenience) - either manufacturer supplied or home-made - and, further, eliminates any possibility of adapting the lathe for through-spindle vacuum chucking. The most significant "negative" of this sanding disk is the safety factor - having an abrasive surface whirring about, directly adjacent to the headstock as you turn, is just plain unsafe! I sometimes need to get "intimate" with the headstock when doing some turning procedures and couldn't imagine why anyone knowledgeable with woodturning would put this "add-on feature" onto the headstock. The reasoning, I assume, is to add "another tool" to the main one, to try to convince you that you are getting more for your money. IMHO, the lathe should stand on its own merits, and should not need other tools added to it, particularly if it creates a serious safety issue. This is just BASICALLY STUPID, and "de-Deluxes" these machines right out of my "acceptable to recommend for turners category". Don't go there!
On my Woodturning Links web site I clearly say that I do not recommend Grizzly lathes, but in fairness, have been a Grizzly customer for other tools (drill press, band saw, Vicmarc knock-off chuck, vises, clamps, etc.) for a long time, so I'm not totally "Grizzly opposed"....it's just that I think you can do better with other lathes and just a bit more investment. It seems to me that this company knows very little about the characteristics that make-up a quality lathe. (None of my comments above involve any assessment of available replacement parts, customer service, etc., which I can't comment on - I don't have any experience with Grizzly on these.)
As you mentioned, you get what you pay for. There will be those that love their Grizzly lathes, and some who have them that are moderately satisfied, and tolerate the negative aspects of these machines. My advice, which is probably worth what you are paying for it, is to look at lathes from other manufacturers (IMHO, Jet lathes are among the best values for the money) and compare these carefully before you buy. The additional cash it may take to step-up from a Grizzly machine to another similar machine of potentially better quality will likely pay dividends in performance, ease of operation, and safety. If you're looking just for a 'starter' lathe and intend to upgrade fairly soon, then Grizzly might be a good option, but DON'T sacrifice safety at any price. [Mr. Balolia (President of Grizzly) should really have a look at what kinds of lathes he is producing, and get some advice from people who are actually woodturners; it seems more and more (at least from their catalog) that the company is catering to guitar builders....!]
Good luck with your decision!
Rob Wallace
Re: grizzly lathes
Rob Wallace
Re: grizzly lathes *LINK*
Rob Wallace
>I meant to include this link in my post (above) to help with some comparisons...
Rob
Woodturning Lathe Manufacturers
Re: grizzly lathes
Wayne Kuhn
>I have Grizzly G0462 (link below) I have to say I made this purchase due to budget constraints and very much in need of an upgrade.
The low end speed is a problem with large out of round blanks. Larger than 10" will give you a ride unless very carefully balanced.
Mine is bolted to the floor also. I did manage to get the speed down to 500 rpm by adjusting the reeves drive lever. Still it just a little too fast.
I recently replaced the pulleys (that was treat) because they broke, I believe this was partially my fault for putting a link belt on, the original belt was a lot thinner than the link belt. However the pulleys are made from cheap pot metal or some such.
My complaints are few, I think it is a good lathe if it's all you can afford, however I am saving my pennies for a powermatic.
Wayne Kuhn
Columbia, MD
http://www.grizzly.com/products/Wood-Lathe-With-Digital-Readout/G0462
Re: grizzly lathes
Re: grizzly lathes
>You probably wouldn't be happy with the G0584 - that is a belt driven variable speed like the Reeves drive. You may get a good one, but....
You also probably wouldn't be happy with the G1495 - that is a similar type of drive.
The G0462 also looks to be a Reeves drive.
I had a similar type of drive in my old Delta - and electronic variable speed is definitely preferred. If the drive is tuned right and has good pullies and a good belt, it is an okay drive - but not great.
The G0632 looks to be the best. It is similar to a Jet 1642-EVS. The dealer I typically use sells the 1.5 hp Jet 1642-EVS for $1,599 as opposed to $1,295 for the 1.5 hp Grizzly G0632 ($304 less). They look a lot alike to me (see picture). Jet has the name, and probably a better resale value. I've got this Jet and I'm very happy with it. You probably would be happy with this model Grizzly. It really looks similar to the Jet. You may be happy with one of the others - but they are not electronic variable speed.
Re: grizzly lathes
Gordon Seto
>Woodcraft is selling the Jet with 10% off with free shipping. IMO, the solid 5 years warranty and resale value of the Jet make this an easy decision.
This is an FWW article on HD lathes, Grizzly was at the bottom of almost every category.
FWW HD lathes comparison
