Turning Tulip wood???????
Roger Dunn
Roger Dunn
>A friend's neighbor had to take down a dying tree and when we got there to cut it up for blanks, he told us it was a Tulip tree (?). It was obviously planted as a specimen tree because Tulip trees aren't native to the Pacific Northwest. We need your collective help to smarten us up before the shavings fly. I've searched through these archives as well as other info sites on the web but didn't get a good sense of how this wood reacts when rough turned, stored, dried, final turned and finished. I think the wood is Liriodendron Tulipfera, but it had a few beautiful blue streaks running up the length of the trunk and out the branches. That feature wasn't mentioned in the descriptions I read.
Any help will be greatly appreciated.
Thanks
Roger Dunn
Re: Turning Tulip wood???????
Re: Are we talking tulip poplar?
>Which grows like weeds around here? If it is tulip poplar - it is very "fuzzy", so keep your tools sharp. It doesn't take a crisp line because it is a soft wood. I like it for carving seats, because it is one of the softest hardwoods. It doesn't sand that well - because it is somewhat soft. You may have to "stiffen" it up before sanding.
Finishing is somewhat problematic. If you are staining, it will blotch easily - so I usually use a gel stain. If you are just finishing it with oil, it can sometimes blotch then - so I usually sand it to 320 grit. As you can tell - I come at this wood from a furniture making perspective.
robo hippy
>Most likely a tulip popolar. Fairly common here in Eugene, and an introduced species. Grows fast, great shade tree, and mostly found in the wood stores as popolar. Great for paint grade trim and stuff, but a bit soft for furniture. Can have a lot of nice green and black streaking in it. It is soft and stringy, so very sharp tools, and maybe even wetting the wood for the last few cuts to keep the fuzzys at bay. Stable, and easy to dry.
robo hippy
>Yellow (Tulip) Poplar is common here - I have some trees in excess of 3' in diameter. Some people turn it but poplars not real popular. Some people use it for practice or for testing shapes. Some members of our turning club have made some large bowls and platters. One nice thing is you can get really large pieces and they are relatively stable. I cut some large turning blocks a couple of years ago and I still see no sign of checking.
I've sawn a lot of it for lumber and found it air dries very quickly without warping, at least for boards from the large straight-grained logs I had.
It's soft and light weight for the most part, although I've had some which was much harder and more dense. I made some beehive boxes from poplar once and they were too heavy to use compared to boxes made from white pine.
Tulip Poplar used to be the wood of choice in the Appalachian region for making large practical items such as large hand-carved bread bowls, furniture, and dulcimers. It is still widely used today inside and under furniture for frames and cores. It's often sold for lumber as "white wood". The heartwood can be green and have streaks of yellow, dark grey pink, and brown. If you have blue streaks they might be from embedded metal. One reference book I have mentions streaks of steel blue when mineral stained.
Roger Dunn
Roger Dunn
>Thank you all. This is the help I was looking for.
Roger Dunn
Ralph
>I've turned a little of it dry, I think you will love it (bring some for the Sept wood auction!!)
TTFN (see you at the picnic?
Ralph
Roger Dunn
Roger Dunn
>Ralph,
I'll drag a few hunks in to the Sept. meeting. It is pretty stuff.
My dance card is booked for the picnic weekend.
weekend
Ralph
>Trust me, I understand, I have three things I've been invited to that day alone
