cedarcide turners choice *LINK*
Marvin Ewing
>Has anyone ever tried this product? If you did, did you like or dislike it. I know it's quite expensive at $50.00 per gallon.
http://www.cedarcide.com/woodturners.asp
Marvin Ewing
Re: cedarcide turners choice
Curly Smith
>I'd be reluctant to bring a silicone laden product into the workshop since it might cause finishing problems (fisheyes) on other projects.
Dick Hines
>$50 a gallon? Man I though denatured alcohol was high at $15 a gallon. I think I will pass on this stuff.
Re: cedarcide turners choice *LINK*
Fred Holder
>I've been using the Cedarcide Turners Choice (CedarShield)since 2005 and have reported on the results a number of times in More Woodturning magazine. It does not always keep the wood from cracking; i.e., if the wood has pith in it there is a likelyhood that it will crack somewhat. One thing that I like about the product is that the wood turns significantly better after it has been treated with CedarShield. The first time I realized this was when I was turning spinner tops at the Carving Show in Monroe, Washington in September 2005. I had soaked a half dozen of the top blanks in CedarShield and left the others untreated. The blanks were elm and the grain was along the axis of rotation; i.e., spindle mode. I turned a couple of the untreated blanks and did not get shavings as I cut across the end grain. With the treated blanks, I got little piles of shaving on the lathe bed.
With the balls to make Chinese Balls, I've often found cracks inside the ball when I go to make the Chinese Ball. When the wood has been soaked in CedarShield, the wood cuts better and I've yet to find cracks inside a ball that was soaked in CedarShield. Therefore, I always used balls that have been soaked in CedarShield when doing demonstrations.
I also had come commercial 2-1/2 inch balls that I purchased to make Chinese Balls. The first two that I tried cracked badly. I soaked the rest of the batch (10 in total) in CedarShield. As soon as they had dried I tried a couple of them. They did not crack when cutting and the wood cut significantly better.
The guys in Hawaii that I know, which use the product, spray it on the wet turned pieces and claim they have no cracking. I did this once on a wet turned madrone shallow bowl that was final turned wet to about a 1/2 inch wall thickness. I used a spray bottle to saturate the outside of the piece and set it on the shelf to dry. It warped tremendously, but did not crack. Without the CedarShield, I believe it would have cracked. Normally, however, I soak my wood for at least 24 hours rather that spray on the CedarShield.
I purchased five gallons of the stuff in early 2005 and it has finally died after soaking many many pieces of wood over a three year period. They have a newer version available that seems to work even better now. I've been using a gallon of it for almost a year now.
Personally, considering how much better the wood turns, I don't think the price is that high.
Incidentally, you can only use oil based finishes, because the wood that has been treated with Turners choice rejects water. Wax and oil base finishes seem to work well.
More Woodturning Website
