Need help from the masses
>As some of you know I'm making wooden cupcakes. I can make icing in most colors except white. I have been using Durham's powdered wood putty, but it is tan in color. I got a close to white color but if you mix too much paint with the putty it doesn't harden.
I need this stuff to be the consistency of Icing, or a little thicker than tooth paste.
I thought about Inlace but you have a very short working time when it gets to that consistency and if your too long it would ruin the icing tip. The same is true with epoxy. Also both of these are glossy and icing is inbetween matte, and satin in appearance.
Elmers has a white putty but I haven't been able to find it locally so I can't try it out and see if it works.
Re: Need help from the masses
Bill Grumbine (Kutztown PA)
>How about letting some white glue set up partway and using that John?
John Veerkamp, Western Mo
>John,
you might try light weight joint compound. It is very weight and should set up well. Not as hard as the Durham's but you could shellac over the top for extra protection.
Another suggestion is homemade "silly putty". Flour, water and salt. Salt is a fairly high propotion in the mix. We used to make this for our kids when we were too poor to buy the real stuff. It can also be colored. It sets up fairly hard.
A third possibly is Femo clay. it is available in most craft stores and on line. It comes in many colors.
John
Dick Coers
>How about white dyed polyester resin. You will have to play with the pouring time versus setup time. The penturning guys use 2 drops catalyst per ounce of resin. Some use the powder coat powder from Harbor Freight for the color, other buy from the fiberglas supply guy. With this stuff you might even be able to put a curl on the top of the icing by pulling up some of the stiff resin. It would also let you put on sprinkles as the little bits would stick to the resin. It will be an expensive test though. Polyester resin isn't cheap!!
Steve in NC
>John
How about polymer clay (Sculpty). It will have to be baked though.
You may also consider a light weight modeling clay made by Crayola. Not sure of the name but it comes in a sealed bag and dries in the air. It is very light and easy to work.
Good luck.
Steve
don lewonczyk
>John have you thought of artists gesso, if I remember it also comes in a paste form for impasto art work and I think it comes in a matt finish as well. Its been 18 years since I did any painting and im sure alot of new products are on the market that would fit the bill. Luck, DonL
keith zimmerman, Normal IL
>How thick do you need it? Acrylic paint in tubes would be close to the consistency you describe, but it would probably take an entire tube to cover your cupcake and would have a pretty long drying time. Acrylic paint does come in several different shades of white.
keithz
galen V
>http://www.teachnet.com/lesson/art/playdough061699.html
There is a million ways to make play dough and some is fine texture like frosting. Others a little grainy. Above site just one of many.
Randy G
>So.. I live with a cake decorator and understand your challenge here. The playdough like surface isn't what your wanting, that'd equate to more of a Fondant covering which would be for decorative cakes. Your needing something that is more fluid that hardens. It needs that light fluffy look of frosting.
I agree that the Plastic Resign might be the best idea, though timing and mixing on that will have to be near perfect. The good thing with that though is you can get it in clear at some crafts stores and make it a really really nice white. Other than that, I haven't been able to find the Durham's around here, so can't so I know of anything comparable. What about.. and this is kinda far fetched, but a caulking of some kind. It'd be messy to deal with, but as it set up it'd never get hard (like frosting) but you could put the type of texture into it you needed? That might actually yield interesting results.
White Marine-Tex
Mike from Saint Clair Shores------WebKitFormBounda
galen V
>Frosting Paint (non-edible)
1 cup powdered tempera paint
2 tbsps. wallpaper paste
1/4 to 1/2 cup liquid laundry starch
Mix tempera paint with wallpaper paste. Add starch, mixing until thick enough to spread - like frosting. Place paint on a plastic lid and use popsicle sticks to spread.
Latex caulk?
Mike Jones, Redding, CA
drywall compound
Darryl
Golden acrylics modeling paste
Ed Kelle
>Maybe the light modeling paste, or high solid gel. YOu can mix colors in with them to get all sorts of icing looks.
www.goldenpaints.com
or call them 607-847-6154
very helpful people there
Epoxy with white micro balloons
Don Evans
>It looks just like white frosting.
Here's two products *** Links***
Ron in Drums PA
>First One
Second One
Great Info- I have lots of experimenting to do.
Dick Hines
Dick Hines
>My X wife did ceramics and there was some product that could be tented with pceramic paint to amy shade you wanted. It also made the paint think like snow. Check out the phone book for ceramic shops.
Sorry I don't remember the name. Good luck.
