Index wheels
Steve in NC
>Hi Folks
I am looking to add an indexing wheel to my PM 3520. Any suggestions on sources.
Thanks
Steve
Index wheels
Steve in NC
>Hi Folks
Thanks
Steve
Re: Index wheels *LINK*
>Steve I have 2 sources other than making your own. www.ironfireLLC.com has one that works great. They have them to fit 1" 1 1/4 and also a mini lathe version. I've been using it for the past year or more. They are some sort of tough plastic like nylon and although they look flimsy they hold up really well.
I have just ordered a new one from VM Woodworking. Michael Hare is selling just about the same thing as the ironfire but his is a thicker clear polycarbonate with larger holes. It's really easy to lose the index pin from the ironfire because it's so small (#36 drill I think) Mike's is 1/4" which would be easier to replace if lost and is much larger so you probably won't lose it. His only comes in 1 1/4" hole and is 11 3/4" across if I remember correctly. The holes in his wheels are drilled with a $200,000 CNC machine so they are extremely accurate.
Both of these have the same 4 rings of holes giving you a very wide range of divisions up to 60. By mounting a second index block with it's hole mounted exactly in between you could easily have 120 divisions.
It's fairly easy to make a custom one. It probably won't be as accurate as the others but for most applications it would work fine. Just hot glue a piece of plexi to a waste block and turn a hole for the spindle. Then turn the outside. Now use dividers to step off the number of slots you want and use the bandsaw or table saw to cut the slots. An easier way is to use the program in the link and simply print out the division sheet you need.
I've drilled holes and cut slots. Both work well, it depends on how you want to mount the index block. My next one is going to have a spring loaded foot activated lever that moves into the slot. This will free up both hands to hold the router or other tools if necessary.
http://www.smithart.us/download.htm
LARRY BISBEE
>In addition to the index wheels suggested by John Lucas there is one made by 'Alisam Engineering' that you might want to take a look at.
ALISAM ENGINEERING INDEXING UNIVERSAL SYSTEM
Re: Index wheels
Craig Daymon
>John's provided link goes to Bill Smith's web site. From first hand exposure to Bill's work, I can tell you that he achieves a fantastic level of accuracy using these printed indexing wheel references to do his segmented turnings.
Re: Link for VM
Steve in NC
>John
Thanks for the information. Do you have a link for VM. I was not able to find one.
Thanks
Steve
Re: Link for VM
>Steve He doesn't have a website and I'm hesitant to give out his phone number on the web. Send me an e-mail and I'll give you the info. I just ordered some stuff from him today.
Re: Index wheels
Rob Wallace
>I have an Alisam indexing plate; holes for the various points provide for positions diving the circle in thirds (120 degrees), 20 (every 18 degrees) and 72 (every 5 degrees). The plates are well-built, made of anodized aluminum, and are available for a few standard spindle sizes; probably also custom size by special order. I've talked with the owner; he's a woodturner as well as being a machinist - he is in the process of also developing other products for ornamental turning.
One limitation of the Alisam plate may be the relatively few options for positioning in smaller increments. I would like to try to do a Nittman-inspired basket illusion piece (as seen in the recent Woodturning Design magazine) and I'll need divisions smaller than 5 degrees. I'll likely wind-up bolting a circular piece of 1/4' Lexan to the plate and adding another index wheel to achieve even smaller divisions.
Good luck!
Rob Wallace
Re: Index wheels
don lewonczyk
>Rob, im not to sharp with the lathe and indexing but I read somewhere about a wheel not having all the increments for the job. The guy made all his cuts once around and than loosened the wheel and turned it half of what he first cut and then made the second cuts once around which if it was 5% to start then the second cut made it 21/2% between cuts. I don't know if you can follow me because sometimes I have trouble following me. Take Care, DonL
Re: Index wheels
keith zimmerman, Normal, IL
>I bought the Jet mini kit from Alisam and have it mounted on my lathe. It seems to be very well built and should work well for me. I am now in the process of building a carrier for my dremel to take advantage of it.
Thanks for the link. I had no idea there was an indexing wheel out there that was reasonably priced.
keithz
