Can this be fixed?
Can this be fixed?
Steven Antonucci
Can this be fixed?
steve antonucci
>I bought a used die grinder on Ebay for $1 plus shipping. I have a semi function die grinder that when I took it apart, I found out why. Apparently, there is a crack in the "work perfect" item by where the 1/4" fitting screws in. (See picture) It leaks a significant amount of air our the back.
It looks like a repairable part, but I honestly don't know if it comes out or just looks that way? Before I jam it full of epoxy, is there a simpler way? Can I buy repair parts for this thing?
Thanks
Steven
Re: Can this be fixed?
Dick Coers
>Take out the brass fitting and coat the brass threads with vasoline. Mix up some Devcon and slather it around the female thread. Put in the fitting and hope for the best. Darn it, it's hard to get a good $1 grinder any more!!!!!!! What's the world coming to?
Might be better off... *LINK*
Peter Teubel
>...just buying a new one instead of searching for parts. They are cheap enough to get a few so you can cut down on bit changes.
Harbor Freight Tools Die Grinder
Barry Turner
>I'm sure repair parts are readily available.........in China. You'll probably have to take it in to get the right part. :-)
Cheap Way Out
>Remove the air nipple, wrap with teflon tape, and reinsert with enough torque to reopen the cracked casting. Then apply 2 drops of thin CA to the crack as is. Wait a few hours and repeat to fill and seal the crack with the fitting in place.
Hey, for $1 it's only worth a try.
