chuck issues
chuck issues
chuck issues
Woody in VT
>greetings peoples!!! I have an old (10+ yrs) nova chuck. when I mount a bowl using the jaws (25 mm) in the expansion mode, the bowl turns off center. I have a glaser screw chuck that I use to turn the outside, foot and recess. Having checked things with a dial indicator, the screw chuck is running true within about 3 thou while the nova chuck jaws are not coming together perfectly round. They are about 10 thou off. I can feel that they are not perfectly aligned. Is there an easy fix or is it time to invest in a new chuck? This one has seen lots of use...Thnks in advance for your time and advice.
Re: chuck issues
Re: chuck issues
>Woody Loosen all the jaw screws a tiny bit. Close the jaws until they touch each other and then retighen the screws. If that doesn't work I'm not sure what to tell you.
Re: chuck issues
Re: chuck issues
Cyril Griesbach
>Woody, remove the jaws and make sure the slides of the chuck body and the jaws are clean and then do as John suggested.
Re: chuck issues
Richard Allen
Re: chuck issues
Richard Allen
>Have you ever removed the jaws from the chuck?
The old Nova chucks were known for being picky about position. Many woodturners marked their jaw positions (1, 2, 3 and 4).
You can also get the jaw slides out of order but that usually results in the jaws being way out of whack.
The jaws are made of mild steel. You could take the jaws off and beat on the jaws with a hammer.
Naturally if you are looking for a good reason to get a new chuck this looks like a good reason.
