Rolly Munro
Jim Tusant
>Has anyone got any comments good or bad on the Rolly Munro Hollowing tool?
Rolly Munro
Jim Tusant
Re: Rolly Munro
Lan Brady
>Jim,
I have never used one. But, I watched him turn with it at the symposium. What a beautiful rainbow of shavings that tool made!
Lan
Re: Rolly Munro
Don Orr
>I have also sen Rolly use them in person. I also tried one belonging to a friend a while back and liked it. They are on my list for "someday". Two friends who are very good hollow turners love them. The linkage on the larger tool has been redsigned recently.
Good luck abd let us know what happens.
Re: Rolly Munro
Colin
>I don't have one as I don't turn hollow forms BUT having used a friends if I was in the market for a hollowing tool this would be the one. I have tried several others that he has and IMHO this is by far the best, easiest to use and very smooth finish from the tool.
Re: Rolly Munro
tommy james
>i hAVE BOTH SIZES IN THE MUNRO TOOL. OUR CLUB HAS SEVERAL MEMBERS WHO BOUGHT THEM. MOST EVERYONE LIKES THE TOOL BUT THERE IS A LEARNING CURVE, PARTICULARLY WITH SHARPENING THE HSS DISCS. I HAVE BEEN USING MY TORMEK TO SHARPEN THE DISCS AND I HAVE BEEN HAPPY WITH THIS. I WOULD RECOMMEND THE TOOL AND I THINK THAT THE MORE ONE USES IT THE MORE THEY WILL LIKE IT. I SPOKE WITH ROLLY IN RICHMOND AND EXPRESSED THAT SOME OF US HAD NOTED THE TOOL BECOMING CLOGGED WHILE HOLLOWING GREEN WOOD. HE TOLD ME THAT IN HIS EXPERIENCE THIS IS CAUSED BY HAVING TOO MUCH OF THE BLADE EXPOSED
Re: Rolly Munro
Rob Wallace
>Jim:
I've had the Munro tool for over two years (standard version, before the recent modifications) and LOVE the tool - works well and is highly adjustable. Great for hollowing under the "neck" of vessels and particularly on the inside of the vessel's perimeter, where other tools can't reach. I also talked to Rolly at the AAW Symposium amount it use, and I was exposing too much of the blade, causing clogging with some species of wood, and almost none in others. Adjust this carefully. I've used it with and without the upper cutter guard (...which is essentially the equivalent of a Hunter tool) and it does a nice job, even on open bowls, inside and out. I've not had much experience sharpening the cutter with the included sharpening jig, so I can't comment on this; I use this tool mostly on wet wood, so the cutter has remained fairly sharp for a long time. It would be good to have a carbide equivalent of the HSS cutter to swap-out like in the recent carbide insert tools on the market. I don't think you'd be disappointed in this tool.
Rob Wallace
Re: Rolly Munro
Jim Tusant
>Thanks for the responses from everyone. I have ordered the tool and will give it a go. I'll post a response once I have enough time to comment.
