Stitches - How to
Stitches - How to
Stitches - How to
Chip in Plano
>I have several pieces of wood that have a single split in them. I've done the colored epoxy and inlace to conceal/accentuate them. What I what to try now is doing stitches with an acenting wood. But before I jump in and learn it the hard way, I thought I find a more learned person on this site who can share the steps, jigs, insights, etc.
Can I get an invite to re-join WOW. Thanks and happy turning.
Re: Stitches - How to
Re: Stitches - How to *LINK*
Chuck Engstrom
>Jerry Kermode uses a biscuit joiner to cut a slot where he wants a stitch. There's some info on his process on his website -- see link.
He uses lumber milled to the thickness of a standard biscuit for the stitch itself.
Good luck with it!
Chuck Engstom
Jerry Kermode on Stitching
Here is one with stitches in walnut
Jerry Hall
>and a filling of coffee grounds in a natural edge crotch Madrone bowl I was about to throw away. Used a Veritas bench hold down (Lee Valley) with a block inside the bowl to fix it and freehanded the biscuit cuts as I recall. Milled the walnut to biscuit thickness and then used a #20 biscuit as a pattern for one side. Trial fit. Marked the outside of the walnut, rough trimmed it a bit proud, and then sanded flush.
