Beisemeyer fence observation
Keith Tompkins
Keith Tompkins
>For those who do segmented work as well as flat woodworking, is your table saw equipped with a Beisemeyer fence? It is acknowledged as the best system, but I find it has a flaw that I've never seen addressed. The fence clamps along the front edge of the saw, while the rear does not clamp. This allows the rear of the fence to deflect during use. If you haven't noticed this, apply slight pressure with your thumb against the rear of the fence and observe the amount of movement. I overcome this by clamping a wood block behind the fence, which prevents the fence from moving during use.
Re: Beisemeyer fence observation
>Keith My first saw had a really crappy fence but it clamped front and rear which locked it solidly in place. The fence on my Powermatic is a sort of copy of the Besemeyer. It will only deflect with a pretty fair amount of pressure. I keep thinking I will add a rear locking mechaninsm similar to the one that was on my first saw.
I do most of my segmented work with a sliding table so the fence is never used for this.
Ron McKinley
>I had a Bisemeyer fence on a Craftsman and it worked fine. Later I changed to a Ridgid and it has an aluminum fence that tends to flex with a lot of pressure so I plant a big speaker magnet behind the fence on the cast iron of the saw to keep it from flexing. Works fine....Ron
Jim Shaver - Oakville, Ont
>Hi Keith,
I have a General 350 with a similar fence. While the design is as you mentioned the fence is principly used for a rip function, with all the tangent pressure into the fence before and just after the cut. In 10 years of use I have never seen mine deflect.
Segmented cutting to me is a cross cut function best completed with a cross cut sled or on the a sled on the Bandsaw. As you mentioned, knowing how your machines work will add greatly to working safely.
Take care,
Jim
Keith Tompkins
Keith Tompkins
>Hi Jim, It's important to remember that before segments can be cross-cut, they are ripped into strips. Flex at the fence will affect the accuracy of the rip cut. creating a slight taper. Initially, all pressure is against the front of the fence when beginning a cut, then against the rear as pressure is needed to keep the wood against the rear of the fence. When the segments are cut, then flipped, etc. the angle of the cross-cut is affected each time the strip is cut and flipped if the edges of the strip aren't parallel. The heavier and denser the wood, the worse the problem becomes, as more pressure is exerted against the fence. The problem is much worse when cutting staves. When I teach segmenting, I show students the effect the flexing fence has on their work, and how to clamp the rear of the fence to prevent it.
Best?
Dave Peebles Lyons, Ohio!
>Hi Keith,
I have a Vega fence on my saw. Locks both front and back, no movement what so ever.
I may even move all the bowl blanks off of it tomorrow a see if it still works :)
Dave
Re: Best?
Ed Karch
>I will have to clean all the turning junk off the saw to see if it even has a fence.
Keith Tompkins
Re: Best?
Keith Tompkins
>HI Dave, What prompted this post was a table-saw review by a well known magazine. They excluded the Dewalt saw in the test because it was not equipped with a B'meyer fence......I'm kinda' shocked, because I've been totally unimpressed with their performance. I'd prefer the Vega sight unseen. :)
Peter Hyde
>Well the Bessy is not the best if not set up properly. I chose a Unifence which I think is a better fence, and it has no back rail. A fence needs to be set up with clearance on the back of the blade or you will be getting into kick back mode. Also you should not use a long fence for ripping lumber, the fence should stop just past the centre of the blade. The long fence fastened back and front is for cutting sheet goods and still has to be set with clearance at the back of the blade.
So, this fence...
Steven Kubien
>...is not used on a lathe right? Oh, it goes with the flat turning-stuff-storage-system (T.S.S.S) on the other side of the shop? Well, a fence would be handy to help stuff from going off the side..... Runnin' and duckin'
Steve Kubien
