I feel your pain
steve antonucci
>I have done that more often than I can even recount. In fact, I did it last week on this vessel. I measured it, but it's really hard to get an accurate measurement at the bottom of something 14" deep when you have 1/4" as a goal.
The sides at the top are 1/4", and as I got to the bottom, probably more like 3/8". I assumed I still had at least an inch of wood at the transition point, but found out I was way off when I cut through the bottom and it was spinning around my boring bar.
The good news is that I had planned to do something with this one that didn't rely on the wood being perfect, so I decided to put Humpty Dumpty back together again. I started with a little epoxy to get the wood reconnected at 3 points, and then slowly filled in the 1/4" gap with epoxy and shavings. Sanding in between layers (like automotive body work)...
Might be an opportunity to try a new process?
Steve
